Code p2770
Old Nov 24, 2021
Frostysinco's Avatar
Frostysinco is an unknown quantity at this point
Code p2770
D light keeps blinking and the car is having acceleration problems at the beginning
Old Nov 24, 2021
FRSam's Avatar
Click Here
Re: Code p2770
https://www.7thgenhonda.com/threads/...0-code.210473/
Old Nov 24, 2021
Re: Code p2770
I have a new solenoid in the plug in clip is broken but it’s in??
Old Nov 24, 2021
FRSam's Avatar
Click Here
Re: Code p2770
I would look at replacing the clip. If not that, check the basics i.e fluid level/quality.
Old Nov 27, 2021
Re: Code p2770
how do I replace the clip without having to replace the whole harness
Old Nov 27, 2021
Colin42's Avatar
Re: Code p2770
You can buy the clip with 2" long wires that you splice in....
or go to a junkyard and cut one off yourself
Old Nov 28, 2021
Re: Code p2770
is there a video on this I can go by. And would over fill of transmission oil be the problem?
does the fluid have to be pperfect in between the line of the transmission dip stick
Old Nov 28, 2021
Colin42's Avatar
Re: Code p2770
It's crimping 2 wires, if you can't figure this out maybe stop working on cars...
and yes too much fluid can cause problems
JAG609
Feb 22, 2003 11:50 AM
Tofoo4life
Feb 2, 2003 03:49 AM
Samari
Jan 19, 2003 08:45 PM
vdub
Dec 13, 2002 09:06 PM
Dustman380
May 10, 2002 12:15 PM
