My cv axles won’t slide into the differential [solved]
Old May 13, 2021
EM2-EMMA's Avatar
I’m a guy. My car’s name is Emma.
EM2-EMMA is an unknown quantity at this point
I just rebuilt my 5-speed, all new bearings and synchros. Even replaced the bearings on the diff, cuz I had it all out. Put everything back AS WELL AS I POSSIBLY COULD. Now the OEM and the new cv axles won’t slide in. Stops like the splines aren’t engaging. I’ve tried removing the ABS ring, no different. Both sides are the same issue. The inner splines don’t appear to be dinged or dented. Pretty sure Rockauto sent me the correct Manual axles. Any ideas?
Old May 13, 2021
re: My cv axles won’t slide into the differential [solved]
if it's on the knuckle side, remove anti-roll bar endlinks, let arms move freely
it's pretty tight fit, it's normal. Need to align very well
wriggle around
I think i did remove ball joint too
Old May 13, 2021
EM2-EMMA's Avatar
Sorry, no, it’s on the trans side. They go in the knuckle side fine. I have the top strut mount loose and the whole hub swings out the way. ✅
Old May 13, 2021
then push.
rotate slightly
push
wriggle
rotate
push
Old May 13, 2021
EM2-EMMA's Avatar
Been doing that for 2 hours
Old May 13, 2021
rubber mallet
Old May 14, 2021
BrotatoChip's Avatar
Super Moderator
I've gotten an axle to pop in the diff by hand maybe three times. I usually put one end of my breaker bar up against the end of the CV cup and hit the other end with a rubber mallet to pop it in place.
Old May 17, 2021
Wankenstein's Avatar
Use a light coating of transmission grease or synthetic grease such as Superlube or Napa Syl-Glide on the inner CV axle spines and locking ring being inserted into the differential. Then use Brotato's suggestion.
Old May 17, 2021
EM2-EMMA's Avatar
Imma try his method. ✅
Old May 17, 2021
EM2-EMMA's Avatar
Yep! They went in! All good!
just needed more persuasion with a rubber mallet in the right spot. Moving on
Thanks again guys
Old May 17, 2021
it's annoying how those are stubborn to go in.
at the heat of battle, it's hard to believe in what we are saying, but it's just.... stubborn to go in...
congrats! Welcome to the club for swearing for days on in to the axle to go in!
supermex
South
Jul 19, 2002 12:59 PM
nrrhgreg
Jul 1, 2002 02:59 AM
CivicMexicano
Jun 4, 2002 09:24 PM
Unomyname
Jan 21, 2002 12:03 PM
