stiff shifter [solved]
Old Aug 25, 2020
DavidKing's Avatar
DavidKing is an unknown quantity at this point
2002 honda civic ex - automatic
Shifter is stiff after car parked for a few weeks. Any ideas on how to free it up?
Old Aug 27, 2020
mac25's Avatar
Dr Krieger of Modification
re: stiff shifter [solved]
Pull the cover and spray the slide with lubricant, perhaps.
dont hit anything electrical.
Old Aug 27, 2020
DavidKing's Avatar
Thank you.
Tried that and it helped. There was white grease from factory that had dried out. Applied lithium grease, and hopefully it resolves the problem.
Old Oct 27, 2023
DavidKing's Avatar
Re: stiff shifter - FIXED
Had to replace the transmission shift cable and all the problems got resolved. The old cable was seized from years of salt and corrosion that seized the swivel end of the cable, which caused the problem.
My cable was completely seized and had to be replaced. But if someone is experiencing intermediate symptoms which is how the problem initially starts with vehicle not going into "P" (Park), the covers (2 of them at bottom of tranmission) can be taken off the cable to transmission and then spray it down with a good lubricant (Not WD 40) at the swivel joint. This will most likely solve the problem.
Old Oct 27, 2023
BrotatoChip's Avatar
Super Moderator
We appreciate you coming back to update the thread!
Cj1234
Sep 17, 2022 08:58 PM
Rams00123
Electrical
Jun 26, 2022 03:31 AM
TheGood
May 23, 2006 03:58 AM
Grey
18
Feb 15, 2003 02:02 AM
Bigdaddyd59
Jul 4, 2002 11:15 PM
