car thinks is in drive when in park
Old Feb 6, 2005
mndthegap1's Avatar
i dont know waht the problem is...
the past few days, after i drive around and then park the car.
if i take the keys out and then try to start it, it wont start, it show on the gauge cluster the symbol for drive blinking while the park symbol is still lit aswell. anyone know what this is cause from or how to fix ?
the work around ive had to do is lift the console, and hit the white button underneith (cars auto) put it in drive, again, then back to park reset the alarm and then its okay.. its becoming a real pain in the a$$...
Old Feb 7, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
If you are getting a blinking "D" that means the ECU is throwing an error code. Your car's ECU has detected a fault in your engine, transmission, ...etc. You need to get a dealer to read it or someone may have already written about how to read error codes in this forum. Do a search for error code.
Old Feb 11, 2005
excoupe69's Avatar
excoupe69 is an unknown quantity at this point
should have gotten a manual
Old Feb 11, 2005
streetglower's Avatar
you will still have problems with a stick. Most likely you will have problems sooner then with an auto tranny.
Old Jul 6, 2022
frankie1287's Avatar
frankie1287 is an unknown quantity at this point
Re: car thinks is in drive when in park
Hey bro im literally stuck sitting in my driveway right now with the same problem was wondering if you could walk me through or be a little more specific on how you did
do is lift the console, and hit the white button underneith (cars auto) put it in drive, again, then back to park reset the alarm and then its okay.. its becoming a real pain in the a$$...[/QUOTE]
Old Nov 12, 2023
Shai808's Avatar
Shai808 is an unknown quantity at this point
[/QUOTE]
do you have pictures of how to resolve it. It’s happening to me and now I was able to get it to work. But when I turn the ignition on the d is lit as well as the parking
Old Nov 12, 2023
Colin42's Avatar
This was 18 years ago. Can you start it in neutral?
Old Nov 12, 2023
Shai808's Avatar
No, I did disconnect the battery and tight all connections where the shifter is. The battery was tested good. And the starter is new. Now it seems to work after checking the connections, but this is the second time in three months that I was stuck at a store because of it.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
ChristinaVHH
May 10, 2015 03:51 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
smmahan
Apr 15, 2015 08:17 PM
