Clunking noise on Low RPMS
Honda Civic 2004, Anytime I'm in low RPMS I start to hear a clunking noise on my front passenger side. The Lower the Gear while in low RPMS, the more apparent it gets. Usually the clunking lasts 1 second in 2-3 second increments. If I'm driving it Like I normally should in the correct RPMS, I dont notice it but it didnt make this sound before I swapped out a Refurbished CV axle, Throw Out bearing, Clutch kit, bled the brakes, and opened up the transmission. Nearly Everything was torqued to Spec. My clutch is a little flat and I still need to bleed it some more but any ideas on what could cause this? Being that it progressively gets worse from 1st-5th gear I dont think I damaged the transmission but I'm thinking maybe I got a bad refurbished CV axle? I'll be taking out the cv axle tomorrow to see if there is any apparent damage.
Any ideas?
EDIT: I want to add that it shifts into gear no problem as well.
Any ideas?
Received 1,450 Likes
Rep Power: 339 Re: Clunking noise on Low RPMS
moving thread out of DIY, not and DIY article.
The following users liked this post:
Perfectionist (07-18-2020)
Any ideas?
Click Here
Received 1,157 Likes
Rep Power: 99 Re: Clunking noise on Low RPMS
Just sounds like a tired transmission to me. I’d suggest throw-out bearing if you hadn’t replaced it already but obviously that’s not it.
CV axle usually only make noise at low speed.
We will see.
So I'm back on this fun little disaster again, this time. I jacked the car up. Had someone shift into 1-5 at low rpms and laid right underneath the transmission. I couldn't hear any weird sounds, it sounded good. Thought it went away, then I asked the driver and he said he could hear it. As if something was loose near or in the transmission. I have no idea and I'm about to give up tbh.
I just had this random thought...what if my motor mounts are bad?! Could that cause the engine to shift to the point that I'd be getting a grinding sound. Whats weird is I cant hear anything noticeable from outside of the car but its very very noticeable from inside the car.
UPDATE!!! I am so happy to say that, I ended up taking out the CV axle once again, having someone help me. While I put pressure on the transmission end, I had someone use a rubber mallet on the other end knocking it in no problem.
THE SOUND IS GONE!!
What is strange is when I took it out, there was zero scrapping, or damage on the threads but for some reason, the noise is gone when I put the cv axle back in. For now, the problem is solved. Thank you. I can finally move on to the next project.
THE SOUND IS GONE!!
94Solman
07-27-2012 09:02 AM
mdwood2
07-08-2012 05:05 PM
WD40
20
06-08-2004 04:25 PM
