Weird Noise / Hard to use gear selector
Old Apr 16, 2020
DamianJBurgos's Avatar
DamianJBurgos is an unknown quantity at this point
Exclamation Weird Noise / Hard to use gear selector
Hi all,
I just bought a 2004 Civic and it makes this weird grinding sound when you release the clutch, it's also very hard to move the gear selector left to right but it moves fine up and down, are these 2 issues related to separate? The car has 161K miles.
Please see attached link to video of the noise
https://photos.app.goo.gl/9MyEVdnRQP27zgtn8
Old Apr 16, 2020
Colin42's Avatar
Re: Weird Noise / Hard to use gear selector
Noise is most likely the input shaft bearing, have to take the trans apart to fix. Gear selector might be the cables or maybe the shifter ball is split.
Old Apr 16, 2020
Thanks! I was looking at some bearing overhaul kits on Rockauto, the person I bought the car from said it was sitting for a few days and when he started it up a few days later that's when the gear selector was hard, we live in Boston, Mass could some rust build-up that quick? Should I put some PB blaster down in the cables? I would look into the shifter ball but like I said the gear selector was fine before the car sat for a few days.
Old Apr 16, 2020
Colin42's Avatar
If you believe that I have some beachfront property in Arizona you're going to want to look at.
All joking aside, rust build up isn't going to happen that fast, the seller might be telling the truth that it only started acting up recently, but I doubt it. Check the ball, check that the cables aren't getting hung up. Maybe someone else will have some other ideas
Old Apr 16, 2020
I’m new to the manual transmission side of the world so this might be a dumb question, is the shifter ball part of the gear selector or is that inside the tranny?
Old Apr 16, 2020
Colin42's Avatar
Ball is on the bottom of the gear stick, you'll have to pull some trim to look at it. Search the forum there should be a couple threads about the issue, might even be some pictures
gmanscivic
Transmission
Mar 2, 2019 02:40 PM
joey72
Dec 1, 2017 12:49 AM
mani_is_kool
Jun 14, 2009 10:20 PM
MeguiarsEM2
Mar 14, 2006 11:38 AM
nerd4president
Dec 10, 2003 01:28 AM
