LX Civic Transmission
Old Feb 23, 2020
Gaytac0's Avatar
Really not ***
Gaytac0 is an unknown quantity at this point
Hello all 👋 my transmission is showing signs of wear. My mechanic took a look and told me I should consider a rebuilt/reman replacement. Been hunting around salvage yards and found a 5spd manual for my car, but it’s the DX model. What are the differences, if any, between the VTEC/nonVTEC transmissions?
Old Feb 23, 2020
FRSam's Avatar
Click Here
Re: LX Civic Transmission
They gearing is slightly different, but they’re basically the same
They’re straight swaps if that’s what you’re asking
Note: I’m assuming you’re comparing d17a1 and d17a2 transmissions. K-series (Ep3) transmissions will not work at all
Old Feb 23, 2020
Colin42's Avatar
Do you have a VTEC motor (d17a2) or a non-vtec (d17a1)?
If you put a non VTEC trans in a VTEC car you acceleration with be slower.
You can put a VTEC trans in a non VTEC car and gain acceleration (I've done it)
Old Feb 23, 2020
Gaytac0's Avatar
Really not ***
Yes mine is the D17A1. Gaining an acceleration boost would be awesome! Also-would the valve cover from the D17A2 be a direct swap too?
Old Feb 23, 2020
Colin42's Avatar
The valve covers are identical?
Old Feb 23, 2020
Gaytac0's Avatar
Really not ***
I figured there would be some sort of variation for a DOHC. Thanks for the help tho guys! Much appreciated
Old Feb 23, 2020
All d-series engines are sohc. That said. The d17a2 is the vtec variation of the non-vtec d17a1
Old Feb 23, 2020
Colin42's Avatar
This, the only difference is the a2 head has the VTEC solenoid and the different camshaft and rocker assembly
Old Feb 23, 2020
FRSam's Avatar
Click Here
Well, there is one dohc d series, and it wouldn’t work. The d17 is a bit of a bastard child when it comes to other d series, because only d17 works with d17 (for the most part, there are some exceptions but they don’t have the cross-compatibility that the rest of the d series have)
valdog7
Jul 19, 2014 07:05 AM
zilievski
Sep 14, 2008 07:17 AM
simo
Nov 7, 2006 07:31 PM
wil
Mar 10, 2004 02:16 AM
PESTLNC
Oct 28, 2002 10:48 PM
