Transmission
Old Dec 10, 2019
01em2ex's Avatar
01em2ex is an unknown quantity at this point
Transmission
So my civic struggles to go into first gear, i have to go second then first for it to pop in. Whats the problem?
Old Dec 10, 2019
Re: Transmission
You talking about from a dead stop or while moving?
If it's the former, could be that the synchros aren't lining up 100%. Dogteeth could be worn down a bit and slight misalignment will cause more of an issue than fresh gears in the tranny. Shifting into second aligns them a bit better so it'll go into gear. You typically hear about the same issue, but usually with reverse gear, and not only the 7thgens, but older d-series civics as well. IIRC, it was habit (in my 2002) for me to shift into 2nd then back into first, but I attributed that to me being fidgety.
If the issue is while you're moving, yeah, it prolly won't let you readily shift into first while in motion. Maybe if you're going at a snail's pace, but that's about it. Like, as you're braking, and just before the car is stopped.
Old Dec 10, 2019
01em2ex's Avatar
Re: Transmission
Im talking about at a dead stop. It won't go into first unless I go second then first. Sometimes it will go into first if i slowly let the clutch out, it'll pop in but that's rare.
Old Dec 10, 2019
Re: Transmission
Synros, almost for sure. LIke 95% positive at this point. You can either a) suck it up and/or see if a tranny fluid change helps (won't 100% fix, but might help) or b) spend the $$$$ to have someone rip apart the tranny to inspect and/or replace the synchros. Do you have any issues with your car popping out of gear randomly?
Hoochrulez55
Aug 24, 2013 10:25 PM
Ricanwizard
Jun 10, 2009 06:49 PM
joe_honda
Feb 16, 2009 01:49 AM
ShockTroop420
May 6, 2008 01:22 AM
BasicEssentials2k1
Feb 17, 2004 01:37 PM
