Stray Metal piece found in flywheel
Old Aug 8, 2019
Matt.g's Avatar
Matt.g is an unknown quantity at this point
Was hearing a noise coming from flywheel, opened the black flywheel cover where transmission meets the motor and this metal piece came out. Any idea what it could be from? Car seems to be running fine at the moment and the noise is gone just trying to figure out what's broke since I can't open the transmission myself. 02 manual civic
Old Aug 8, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Stray Metal piece found in flywheel
Oh, that's a quarter.
Jk.😋
Old Aug 9, 2019
Slumpertcivic's Avatar
My first guess would be that broke off the throwout bearing.
My second guess would be it’s a shim from a aftermarket starter.
Neither would be of particular concern to me, but I would “verify” the starter is disengaging by briefly trying to start the car while it is running.
If you hear the starter gears grind, your fine, but if it’s quiet you should put get a new starter on your short list.
if it was one of the bearing hold tabs, when the other one breaks you will start hearing some really funky noises when the clutch is out and that whole bearing is spinning against the clutch fork.
Kevinleyster
General 8th & 9th Gen
Dec 8, 2018 04:42 PM
Alfie17
Engine start problems
Sep 12, 2018 12:35 PM
Mckenneth
Dec 9, 2017 08:42 PM
Weslinds
Jul 15, 2017 12:45 PM
Arcadius
Mar 19, 2017 09:50 AM
