How-to: Tear Down and Rebuild 2002 Honda Odyssey Automatic Transmission
SubscribeHello, I will be showing you how to tear down and rebuild your automatic transmission (transaxle) on your Honda/ Acura. The NHTSA published several reports detailing the results of their findings on the automatic transmission failures for the TL 3.2L engine. I am talking about all of the Honda/ Acura transmission recalls of this era. This should include the 2001 Civic and others possibly. The report states the causes of these transmission failures. If you look at the video description it links to my 2 articles about which parts are causing the transmission to fail and the solutions I found. For the Civic or any transmission that is not an Odyssey just inspect every clutch pack and IF one of them is destroyed than you need to enlarge (grind out) the oil lubrication holes for the thrust washer for that clutch pack as well as replace the needle bearings for that specific clutch. This info applies to Odyssey's, just adjust the info to your civic if you find a destroyed clutch pack:
https://www.odyclub.com/threads/quic...ission.353519/
https://www.odyclub.com/threads/foun...roblem.352145/
This is a massive video series. It will get better as it progresses so if you are patient it will be worth it. Explains all you ever wanted to know about these transmissions.
Make sure you watch in the highest quality setting: 1080p. Although this is for a 2002 Odyssey, they use very similar designs for many vehicles. the slight differences would be, for example, the orientation for the step groove on the reverse selector ring. These were the ones on the recall list however many other transmissions were similar, so this guide applies to a huge list of vehicles not on the recall:
2001 Honda Civic (other years?)
2002-04 Odyssey
2003–04 Pilot
2001–02 Acura MDX
2003–04 Accord V-6
2000–04 Acura 3.2 TL
2001–03 Acura 3.2 CL
Part 1:
Part 2:
Part 3
Part 4
Part 5
Part 6
Part 7
Also part 13 will be one of the most important parts, it talks and shows the thrust washer for 3rd clutch for the 5 speed. for 4 speed auto transmissions you will need to grind out the thrust washer for 2nd clutch yourself. the links for the 2 articles I wrote explain it
Part 8
Part 9
Part 10
Part 11
Part 12
Part 13 (an important part)
Part 14
Part 15
Part 16
Part 17
Part 18
Part 19
Part 20
Part 21
Part 22
Part 23
Part 24
Part 25
Part 26
Part 27
Part 28
Part 29 (This is the last part)
2002-04 Odyssey
2003–04 Pilot
2001–02 Acura MDX
2003–04 Accord V-6
Part 1:
Part 2:
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
Part 10
Part 11
Part 12
Part 14
Part 15
Part 16
Part 17
Part 18
Part 19
Part 20
Part 21
Part 22
Part 23
Part 24
Part 25
Part 26
Part 27
Part 28
