04 civic vtec swap
Old Mar 26, 2019
Rodgers18's Avatar
Rodgers18 is an unknown quantity at this point
04 civic vtec swap
I swapped the non vtec with a vtec now the tranny won’t mount up the torque converter won’t fit????
Old Mar 26, 2019
mac25's Avatar
Dr Krieger of Modification
Re: 04 civic vtec swap
It should.
The block is the same
D17 is the block style, SOHC 1.7L
A1/A2 is the head.
So if you had a D17a1 you shouldn't have any issues using that tranny with a d17a2.
What's your goal? Need new engine or just want vtec? If you just want vtec then you can swap the head from the a2 on to the a1 block (plus some other stuff)
Old Mar 26, 2019
mac25's Avatar
Check the two guide pins between the block and the tranny to make sure those are lined up.
RFoxx
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 29, 2020 10:44 PM
me_in_jax
Dec 25, 2010 11:59 AM
dwils
Oct 21, 2010 08:41 PM
HwNpRyDe_CiViC
Feb 19, 2007 12:29 PM
Dasica
Apr 3, 2004 10:57 AM
