transmission noise (video)
Old Mar 21, 2019
S14's Avatar
S14
S14 is an unknown quantity at this point
Exclamation transmission noise (video)
Ok so I have this annoying automatic transmission sound . 2001 7th gen vtech anyways I have video of the noise you might turn the volume down on your device for this.
I have replaced the 3rd gear switch or shift control solenoid and now the car is having issues in the lower gears could this be the other solenoid on the right side of the trans? about 2 weeks ago I tested both solenoids with my snapon scanner and the solenoids were clicking as they should but I feel like solenoid A has gone out.
not sure if i should just find another trans or save this one.
any thoughts on this matter would be greatly appreciated. thanks ahead for your time.
Old Mar 22, 2019
mac25's Avatar
Dr Krieger of Modification
Re: transmission noise (video)
So there were no issues and with the new sensor there are issues?
If so, I'd try to put the old sensor back, or buy another from honda.
Old Apr 2, 2019
S14's Avatar
S14
getting the A/T clutch pressure control solenoid A and B in a couple of days. already replaced the shift solenoid A and B also the 3rd gear solenoid under the thermostat housing. I will update once i get the part in.
Old Apr 2, 2019
S14's Avatar
S14
The old sensor was completely trashed and the o rings on it were in horrible condition.
it fixed my D- light flicker for a little while. But, then it started flickering again so I chased all my grounds and sanded the areas down and replaced all the 10mm bolts with new ones then sprayed them with battery protector.
That alone made a world of difference through out the whole system.
We often have to clean up grounds @ Nissan .
The car drove fine then a domino effect happened replaced another solenoid and now about to replace the last solenoid when it shows up.
Old Apr 4, 2019
S14's Avatar
S14
Incorrect gear ratio p0730 I will be ordering a transmission rebuild kit yay me!!!!
9812Valve
Transmission
15
Jun 14, 2021 02:24 PM
Pzern
Jul 20, 2018 07:40 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Jul 12, 2015 11:54 AM
Zaridar
May 28, 2014 11:19 PM
