Cv axle wobbles
Old Feb 24, 2019
Justadude's Avatar
Justadude is an unknown quantity at this point
Question Cv axle wobbles
Good day fellas. I’m new here, any help would be greatly appreciated. .thanks
Here’s my problem, my civic the driver sides axles seems to wobble when I tested it on the jack stand. Passenger side not so bad. When making left turns or sharp u- turns, you can definitely feel the difference. The feeling like you have a over size tire on. You can also feel it on the highway when accelerating from 0 to 55 then when your at cruising speeds it seems to go away. All my tires are new, I check the lower control arm and there’s no play. The axle also don’t have any play but when I tested it with tires off and on jacks, u can see the wobbles on the axle it self. I hope it ain’t the tranny and just the axle itself.
Any help would be much appreciated and thanks again for reading. Have a good day..
Old Feb 25, 2019
Re: Cv axle wobbles
got video?
Some visual shaft "wobble" may be normal and expected due to how a CV joint works
Old Feb 25, 2019
Justadude's Avatar
Re: Cv axle wobbles
Thanks for helping and here’s a quick clip
Old Feb 25, 2019
Re: Cv axle wobbles
I don't see anything at all here
Old Feb 25, 2019
Justadude's Avatar
Re: Cv axle wobbles
Don’t know why it’s not working, I’m uploading and it’s not showing...
Old Feb 25, 2019
Justadude's Avatar
Re: Cv axle wobbles
[QUOTE=Justadude;4758927]
Ok, here’s the video I uploaded on youtube
Old Feb 25, 2019
Re: Cv axle wobbles
When were the symptoms first noticed?
(immediately after some work on the car?)
Old Feb 25, 2019
Justadude's Avatar
Re: Cv axle wobbles
[QUOTE=ezone;4758934]When were the symptoms first noticed?
(immediately after some work on the car?)[/QUOT
The symptoms were couple years back don’t know when it started but the shakes n vibes while going up hill and making left turns got worsen as times went and ideally it got more noticeable thats why I’m trying to fix it now.
Old Feb 25, 2019
Re: Cv axle wobbles
I just found some cheapo replacement axles under 50 bucks each from Autozone
Old Feb 25, 2019
Justadude's Avatar
Re: Cv axle wobbles
thanks, but I don’t really want to throw parts at it. I’m trying to pin point if it’s the axle or the hub bearing or maybe the transmission.
Old Feb 26, 2019
Re: Cv axle wobbles
It's not either of those. I'd throw the axle at it.
Without actually removing and stripping the axle shaft to see everything, I was trying to figure out what could have happened to the axle or inner CV joint to cause the problem.....
Like maybe during some front end work someone pulled the shaft out of the inner CV cup far enough that a roller dropped out of place.
Old Feb 26, 2019
Justadude's Avatar
Re: Cv axle wobbles
Yea I was thinking the same also... . I’ve seen couple video on YouTube on different cars, their axle wobbles and it ended up being their hub bearings. But theirs hub bearings makes grinding noises and mines don’t. What’s wierd is my axle don’t have any play on it.U can hear a tiny click when rock left to right, I heard that’s normal though. The bearings ,lower control arms are all rock solid and is not lose..the passenger side axle wobbles but not as bad ... shouldn’t the axle turns true symmetrical. Others have said its normal to have a little wobble ... but mines seems over the top
Old Feb 26, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Cv axle wobbles
Maybe damage from a sideways curb bump?
Old Feb 26, 2019
Justadude's Avatar
Re: Cv axle wobbles
im thinking the same, somebody must hit a curb hard and bent the axle.. it’s my daughters car and she’s a first time driver ...
Old Feb 26, 2019
Re: Cv axle wobbles
I think suspension parts would bend before an axle would (but there's no telling what really happened, nor what happened while someone else had the car)......but that makes me wonder.....if the wheel (hub/knuckle) has been moved in toward the transmission that may cause the inner CV joint tripod to 'bottom out' in the inboard cup? (it has to ride somewhere near the middle of the cup in order to allow the axles working length to change with the suspension and steering movements)
I was kinda expecting inner end of the axle shaft to 'wobble' 3x per revolution following movement of the 3 rollers on the tripod inside the inboard joint
But yours is not like that....... that axle looks like it's got a problem, one way or another.
Old Feb 26, 2019
BrotatoChip's Avatar
Super Moderator
Re: Cv axle wobbles
My local Pick A Part offers axles for $26, $31 with core charge. If you could find a decent one that's an option if you don't want to splurge on a $50 new one.
Old Feb 26, 2019
Justadude's Avatar
Re: Cv axle wobbles
[QUOTE=ezone;4758955]
Thanks , you’ve been very helpful. It makes sense what you just said. I bite the nail and go ahead and change the axle. I will update soon.
Old Feb 26, 2019
Justadude's Avatar
Re: Cv axle wobbles
yea, I’ll probably look around for cheap axels if not I just grab one from a local shop. The only way to know is to replace ..
thanks
Old Mar 2, 2019
Justadude's Avatar
Re: Cv axle wobbles
I replace the axle today and it seems to be running smoother then before.. When I was under the car today , just my luck I found a torn rack and pinion boot.
Theres no power steering leaking but the bottom is full of grease. I just order one from the dealer, it cost $5 bucks and I’m getting it done Monday . Im just going to throw a bunch of grease on the joints , shaft and call it a day. Don’t know how long it’s been open to the environment but hope no dirt and grinds are in the rack yet..,
thanks a ton guys...
ohanahorse
Feb 24, 2013 04:32 PM
ohanahorse
Feb 3, 2013 08:58 AM
yeabmx
20
Oct 16, 2009 11:45 PM
02blackcivic
Jan 20, 2006 11:15 PM
nindoo
18
Jun 28, 2005 11:51 AM
