Axle Keeps Popping Out
Old Nov 20, 2018
Mizproper's Avatar
Mizproper is an unknown quantity at this point
I have a standard Honda civic and I am dealing with the same issue. The passenger side axle is popping out when I'm driving. Have no clue why its happening.
Old Nov 20, 2018
Colin42's Avatar
Re: Axle Keeps Popping Out
Is it the stock axle or is it an aftermarket one? Are you sure it's installed properly? is the suspension modified or damaged?
Old Nov 21, 2018
Slumpertcivic's Avatar
If it’s a sudden occurance with stock parts, I would suspect the inner CV joint is jammed and the engine/transmission mounts are failed.
If it suddenly started after replacing the axle, well same as above but also possible it’s too short.
Mr Radio
Transmission
Mar 25, 2019 02:15 PM
wesintexas
Jan 9, 2011 05:50 PM
yeabmx
20
Oct 16, 2009 11:45 PM
BenDover
Sep 16, 2009 01:45 PM
integ108
Aug 24, 2003 05:15 AM
