Transmission Help!!
Rep Power: 0 Transmission Help!!
Hi I have an 02 civic ex thats manual.
My problem started last night I was on my way home from work, stopped at a red light making a left turn.
I went from 1st gear to 2nd and then my car will not go into gear,
I pull over and turn the car off and then turned it on again put it on first gear but the car wont move, put it in 2nd gear and it wont move but makes a grinding noise if I gave it gas.
Also if I put the car in 1st gear and release the clutch the car does not stall..
Does any one know what this could be help thank you.
Rep Power: 0 Re: Transmission Help!!
have u try changing the fluid?
and about the car in first gear without stalling check the clutch pedal switch there should be 2 sensor right there i remember reading somewhere about this b4
jackoncruzpr
09-29-2015 07:59 PM
Elciteeve
09-28-2015 12:40 PM
jerry38
09-20-2015 08:38 AM
