Transmission issue - Slave Cylinder?
Old Mar 31, 2009
ClickRight's Avatar
ClickRight is an unknown quantity at this point
Hey everyone,
I have a 2004 Civic Si with intermittent issues changing gears. I have already had the transmission replaced under warranty, and still have the same issue. I recently brought my car into the dealer, and after explaining my issue, the first thing they said was the slave cylinder. They looked at it, and said they adjusted the clutch linkage to the master cylinder. After that, things were much better for about a week. I have a suspicion that they simply greased up the slave cylinder. However, my mechanic is still not satisfied that that the slave cylinder is the issue.
Here are the symptoms:
  • All gears are randomly difficult to engage (feels like it's catching)
  • If you press the clutch down very fast and hard, the issue will often go away or lessen
  • when the clutch is squeaking (appears to come from the slave cylinder area) the problem is more prevalent
Any ideas? Do you think it's the slave? If so, how much should it cost to replace, I was quoted $200 CAD by my mechanic.
Old Apr 7, 2009
ClickRight's Avatar
Re: Transmission issue - Slave Cylinder?
Any ideas? This is driving me absolutely insane!
Old Apr 7, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Sounds like it could be the slave to me. Don't pay someone to do it though man. Its not that hard to do. Just swap it yourself.
sysblack
May 13, 2015 08:55 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
bsmiley
Apr 27, 2015 01:27 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
supercivic01
South
Nov 30, 2001 11:27 AM
