manual trans repair or replace?
Old Jul 13, 2006
broken003's Avatar
broken003 is an unknown quantity at this point
Well yesterday my manual transmission started making some noise 2002 Civic LX and through reading the forums it sounds like its an input shaft bearing.
My question is which is likely the better route to go, have the bearing replaced (and maybe other internal components to extend the life), or find a used one and just swap that in there? What price would I be looking at for each of those repairs?
Any additional advice would be appreciated.
Thanks
Old Jul 14, 2006
streetglower's Avatar
well when exactly does the noise occur?
if it is something simple and you have the right tools and the mechanical skills, do it yourself. buying another trans may not be what you need if whats bad is a $10-$50 part.
Now the price to repair anything depends on where you go. just for a bearing, at least a few 100 bucks. now if you want a rebuild, probably more up to a thousand bucks or so. But if you do it yourself, you will save alot.
Old Jul 14, 2006
RHCP0801's Avatar
if you plan on going boosted some time in the future i would rebuild it to save time and money than.
Old Jul 14, 2006
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
manual trans= super easy rebuild, i did mine, replaced all bearings, clutch, flywheel, and pressure plate... before the swap
Old Jul 14, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I was quoted $500 from my shop to install the input shaft bearing.
I bought a new tranny for $450!
Old Jul 14, 2006
Al Gore FTW's Avatar
jdmtytedoridori
exactly. i could have bought a new one for 400, from an 04LX with 4k miles. im sure i could have replaced the bearing myself too, but i started car shopping, and ended up getting more than what i paid for my car new as a trade in, so i bought a new car.
Old Jul 14, 2006
02BLKCIVIC's Avatar
lol^ I got my new tranny with only 3000 miles on it!
Just waiting for this one to drop...
Old Jul 14, 2006
dariusld's Avatar
dariusld is an unknown quantity at this point
I wish my tranny would go out ,so I could get a new car.
Just kidding tranny.
Old Jul 16, 2006
broken003's Avatar
I haevnt been able to find any reasonable used transmissions around here (I live in SE michigan so import parts are not so easy to find.
Can anyone suggest where I can get a deal on a new/used trans as thats the route that I was planning to take.
Old Jul 16, 2006
mr_fobster's Avatar
^^ aye if your gonna get rid of your old tranny ill buy it from you!!!
Old Jul 16, 2006
jdmtytedoridori
try car-part.com man. i searched in michigan, the best i found was an 04 dx/lx tranny with 13k miles for $316, located in harisson, michigan. the 04 trannies are built better fyi.
Old Jul 17, 2006
02BLKCIVIC's Avatar
car-parts.com!
Yep spend about an hour on there you'll find one.
Old Jul 24, 2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
I just recieved my car last week and had the same problem,from when those a$$holes(dealership) changed a peice in my tranny about 3 months ago.the shaft was ruined from bad bearings. Now I drive it and it feels brand new so if I were u I wouldn't buy a new tranny.The price was about $700 dollars,but warrenty covered it.Just to let u know any work the dealer does on ur car u have a 3 month warrenty,here in canada anyways.By the way does ur car make a wierd sound turning right?
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
SgCivic
Bolt-on Engine Performance
Nov 15, 2001 07:31 PM
