Manual Transmission oil leak. How to repare?
Old Jul 6, 2006
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
My manual tranny is leaking oil arouund the inboard joint. Is it difficult to replace the oil seal at this location? If any of you guys have a DIY on this, could you please post it?
Thanks
Old Jul 6, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Thats probably going to be a fun one. My guess is you'll have to rip the tranny apart. Get a manual if you don't have one. I can't check mine for whats involved until I get home.
Old Jul 6, 2006
streetglower's Avatar
if the axle oil seal is leaking, it shouldnt be that hard. remove the axle, then remove the seal and install a new one.
Old Jul 6, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Yep. Just a matter of tools. I did mine in half hour a side.
Old Jul 6, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
what causes the seal to break???
Hard driving? Huge bumps?? Auto Cross???
Old Jul 6, 2006
Jap-Euro Fusion
I checked the manual, here's the page, its the only one relevant for any oil seals near the axles.
Old Jul 7, 2006
It started to leak after i had the clutch disk and pressure plate replaced. I guess it happened while the mechanic was removing the inboard joint. Maybe he did not pull it out straight causing the spindle to rub against the seal!!!
Thanks a lot man! Is it possible to remove the differential assembly without removing the whole transmission off the engine bay?
Last edited by conspiracy90; Jul 7, 2006 at 06:30 AM. Reason: Automerged Doublepost
Old Jul 7, 2006
if thats the case, I would go back and try and see if he will replace it for you. Anytime a new axle is put in, it would probably be wise to replace the seal at the same time.
Old Jul 7, 2006
tinman's Avatar
Yep, he damaged the seal. Have him replace it. They are surprisingly fragile as you insert the axle, but can last forever if you never touch them.
Old Aug 2, 2006
Is it possible to remove the differential cover without removing the entire transmission off the car?
If it's the case, it would be quite an easy job to replace the oil seal. Don't you think?
Old Aug 2, 2006
why not just remove the axle and pop theold seal out. that is usualy how the job is done. the manaul tends to tell you how to do things th long way. they make special tools and seal removal tools for the job. not sure if the housing itself comes apart. it probably does, but not sure.
Old Aug 4, 2006
tinman's Avatar
Naa... the seal pops right out. You use a hook and just pull it out. Or a careful pry with a big screwdriver. Then just tap (gently) the new one in with a big socket to keep it square. It takes 2 minutes with the axle out.
Old Nov 14, 2018
Ara911's Avatar
Ara911 is an unknown quantity at this point
Re: Manual Transmission oil leak. How to repare?
What book is that one? Where I can get it?
Thanks
Old Nov 14, 2018
Colin42's Avatar
check the last couple pages of this thread for a free pdf copy of the service manual
https://www.civicforums.com/forums/1...pdated-10.html
califcamper
Transmission
Mar 22, 2017 09:00 AM
bimmuvfab
Transmission
May 30, 2016 01:13 PM
xeno-a
Jul 8, 2013 07:22 PM
koohobo
Feb 7, 2013 06:17 PM
RonJ
May 27, 2010 12:50 PM
