Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
05 Civic 5MT overheats only when I turn the heater on
Old Oct 14, 2021
Jaybron's Avatar
Jaybron
Jaybron is an unknown quantity at this point
So my car only starts to run hot when I turn the heater on. Could this be a ln indicator of the heater core being bad? I've run it all summer with no issues so I don't believe it's the head gasket. As soon as I turn the heater on it starts running hot.
Old Oct 14, 2021
FRSam's Avatar
Click Here
Re: 05 Civic 5MT overheats only when I turn the heater on
How’s your coolant level looking? Is the overflow reservoir gaining coolant/overflowing?
Old Oct 14, 2021
BrotatoChip's Avatar
Super Moderator
Maybe there is air trapped in the heater core. Check fluid levels, add/remove as necessary while bleeding the coolant system.
Old Oct 15, 2021
Jaybron's Avatar
Jaybron
The overflow is not gaining fluid. The coolant was a little low. I added some. Now the engine temp goes way down as soon as I jump on the highway, The needle goes all the way down to just above the Cold marker. Is it possible someone put the thermostat in backwards? Will they even fit in backwards?
Old Oct 15, 2021
easy to open it and check.
Also, several reports that an aftermarket thermo does not work well in Hondas
Old Oct 15, 2021
Jaybron's Avatar
Jaybron
Ok after some research there is no way the thermostat would fit backwards and I'm going to look at an OEM thermostat now. The one I'm using is called a Failsafe. Anyone else have any experience with these thermos?
Old Oct 15, 2021
FRSam's Avatar
Click Here
Failsafe is the style of thermostat, not the manufacturer. It's designed to lock the thermostat open for maximum coolant flow when overheating occurs. It sounds like it's stuck open.
Old Oct 15, 2021
Jaybron's Avatar
Jaybron
Yeah I'm going to replace that with a OEM thermostat and see if that helps. Also going to raise the front of the car while I bleed the system which I didn't do before.
Frostysinco
Dec 2, 2020 03:59 PM
DohcLs
Jul 24, 2014 12:46 PM
machineintel
Nov 24, 2008 03:44 PM
speedster
Engine Swaps
Jan 12, 2006 12:14 PM
Simon909
Aug 17, 2005 02:51 PM
