Electronics Post your electronic questions here!
Stereo weird issue. 05 value coupe.
Old Apr 27, 2024
Nessmuck's Avatar
Nessmuck the path ginder
Nessmuck is an unknown quantity at this point
Stereo wierd harness issue.
1. i cant find a matching wiring harness diagram.
testing it out and the isnt a key off, key on, ground present. There is an intermittent ground and an intermittent power.
Old Apr 27, 2024
Nessmuck's Avatar
Re: Stereo weird issue. 05 value coupe.
Across the top:
WHT red, red blk, drk grn, grn yel, blank, blank, blank blank.
Across the bottom:
Blk, red, lgt grn, brn, blue blk, blue yel, blank, blank yel red, yel.
Old Apr 27, 2024
Nessmuck's Avatar
Top view.
bottom view.
Old Apr 27, 2024
Nessmuck's Avatar
I have my power and ground sources figured out.
Old Apr 29, 2024
BrotatoChip's Avatar
Super Moderator
1. Yellow/green - antenna lead
2. Yellow/red - ignition
3. Empty
4. Empty
5. Pink - right rear speaker (+)
6. Blue/white - left rear speaker (+)
7. Green/yellow - right front speaker (+)
8. Green/black - left front speaker (+)
9. Red/black - backlights
10. White/red - battery
11. Empty
12. Empty
13. Empty
14. Empty
15. Blue/yellow - right rear speaker (-)
16. Blue/black - left rear speaker (-)
17. Gray/red - right front speaker (-)
18. Light green - left front speaker (-)
19. Red - dimmer
20. Black - ground
Old Apr 29, 2024
Nessmuck's Avatar
Thank you. I found the second fuse under the hood and that fixed it.
blackdog48
Feb 26, 2022 12:47 PM
Edherdman14
May 5, 2017 01:31 PM
speedracer2411
Mar 18, 2007 01:58 PM
