Electronics Post your electronic questions here!
Replacing ECM/PCM/ECU
Old Oct 12, 2019
Jordan2's Avatar
Jordan2 is an unknown quantity at this point
Alright, so I bought this civic about a week ago. When you got in it started it idled rough/funny. It would be very shaky until about 1500RPM, then it would accelerate and act fine. After it warms up it would almost die coming to a stop.
The check engine light was on so I read the codes. There was a few, a misfire in multiple cylinders, P1607 was faulty ecm, and another one. So I cleared the codes, read it again and there was one "permanent code" which was the ECM. So I pulled the ECM and got the same part number re-manufactured unit off of Ebay.
Now, my question is, I heard you have to "reprogram" you key in order for the car to start?
How would I go about doing that?
I work at a dealership so I could have them do it, but can I just bring both ECM's there have them do whatever to make it work? Or??
Old Oct 13, 2019
Slumpertcivic's Avatar
Re: Replacing ECM/PCM/ECU
Pop the fuel pump relay out, bypass it, then drive to the dealer for programming or not.
Old Nov 22, 2019
photiost's Avatar
photiost is an unknown quantity at this point
I had the same issue (faulty ECU) and brought the car to the Honda dealer $60 later all in fine
OffcNeville
Jun 22, 2017 10:22 AM
dominguez
ECU Fried
Aug 22, 2013 08:09 AM
Macgyver
Aug 28, 2010 12:50 AM
CG99
Buy, Sell, & Trade - Archive
17
Aug 17, 2010 10:15 PM
mharnisch
Feb 27, 2009 06:26 PM
