Electronics Post your electronic questions here!
2001 Civic EX Cruise Control Issue
Old Jul 7, 2019
Michael Hughes's Avatar
Michael Hughes is an unknown quantity at this point
Hi... I thought I'd run this question by folks smarter then I.. The Cruise control sets, de-accelerates, and cancels. It won't resume or accelerate. I replaced the switch with new, figuring that was the simple obvious fix. Still the same symptoms. Before I start going any deeper, I figured i'd see if others have had this similar issue and what was the fix.
Old Jul 7, 2019
Colin42's Avatar
Re: 2001 Civic EX Cruise Control Issue
Vacuum issue?
Old Jul 7, 2019
Dang.. I wouldn't think so. This car has like 250,000 miles. been a great car with the typical maintenance issues for a high mileage car. The cruise control sets just fine, i hit cancel and it works. I push the de-accelerate button on the cuise and still good. But if I hit the brake and then push resume, nothing. If i'm set and push that same button to accelerate, Nothing! I'm perplexed!!
Old Jul 7, 2019
Colin42's Avatar
Sorry I must have misread your first post, that sounds like the unit under the hood may have a problem, or the steering wheel button, but you said you replaced the buttons right?
Old Jul 7, 2019
Yes Sir... I replaced the button control at the side of the wheel. Very easy replacement!! But that didn't help!! Thats why i'm asking? I need some help.
Old Jul 7, 2019
Colin42's Avatar
That's why I said the unit under the hood
Old Jul 7, 2019
Yea that was my next step, the module. Just wondering if others had a similar issue before I took that next step..
Old Jul 8, 2019
BrotatoChip's Avatar
Super Moderator
Test the wiring all the way to the under-hood cruise control box first. Got a meter and know how to use it? When the resume/accel button is pressed/held you should see ~12V on pin 7 (light green/black wire) at the under-hood cruise control unit connector.
If you get nothing then the wiring is bad somewhere inbetween the switch and the cruise control unit. If you do see voltage then the cruise control unit is most likely bad.
Old Jul 8, 2019
Excellent!! I'll give that a try. Thank-you for taking the time to respond....
mike
Old Jul 11, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Other checks are: faulty cable reel, open in the wire, blown #4 (10A) fuse in the Under-Dash Fuse/Relay Box, check for voltage at the cruise control box when Resume pressed.
cap737
Electronics
24
Apr 26, 2019 07:58 AM
sdraza1
General 10th Gen
Jan 23, 2019 07:03 PM
CivicDaniel
Jun 24, 2015 01:14 PM
zzip7
Mar 9, 2015 12:37 AM
embry1123
Aug 31, 2012 05:02 AM
