Electronics Post your electronic questions here!
Please Help ! Speedo not working !
Old Feb 28, 2013
VanessaCivic's Avatar
VanessaCivic is an unknown quantity at this point
Hello,
I have hit a bit of a road block trying to fix my speedo in a 2002 civic. I seem to be having a bit of a different problem than most posts on here. My speedo just isn't ever sitting back down to zero. It may ideal at 40km/h one day and 140 the next. it uses that ideal. It seems to gauge my speed fine from there, its just not displaying it properly. As I accelerate the gauge seems to be going up properly. I have checked the VSS and it seems fine, really clean, in good shape. I just pulled apart the dash and everything seems fine, no loose wires running into the speedo. Any ideas, suggestions would be so greatly appreciated ! ! ! !
Old Feb 28, 2013
Re: Please Help ! Speedo not working !
Try a gauge self test first, see if the gauges will all sweep the full range of the dials.
See this post: https://www.civicforums.com/forums/3...ml#post4625110
Then try a "reset" which is disconnect the battery and touch the cables together for like 10 minutes.
If all that fails.......Try another cluster. Sounds like the stepper motor is bad.
Old Feb 28, 2013
thanks so much for the suggestion, I haven't tried that yet !
werdnahall
May 17, 2015 11:37 AM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
