Electronics Post your electronic questions here!
Need Help with 2002 honda civic
Old Jun 22, 2013
god_43's Avatar
god_43 is an unknown quantity at this point
Hello all, I need help identifying some parts? I am looking for an aftermarket keyless entry system that I had installed when I bought the car back in 03. I have checked under the driver kick panel, but did not see anything. Under the passengers kick panel I found this long black cover? Is it ok to remove this and see if the unit is underneath?
https://i.imgur.com/7OBeAtth.jpg
Full album
http://imgur.com/a/y78K6#vZsBMgo
Thank you.
Old Jun 22, 2013
Re: Need Help with 2002 honda civic
https://i.imgur.com/WaRhuymh.jpg Follow the non-factory wires in this pic. The 3(?) wires (yellow, green, black) that have been taped together. The usual place to find an aftermarket accessory is stuffed up in the drivers side of the dash, anywhere there was room to hide it. Follow those wires and you will find it. The first pic of a black thing with 4 wires is the power transistor for the blower fan. Nope, not what you want.
Old Jun 22, 2013
god_43's Avatar
Great!!! Thank you so much.
Old Jun 23, 2013
god_43's Avatar
So the cable ended up leading to this small black box? https://i.imgur.com/P3vzSKoh.jpg
Would this be the unit? There are no cables going out from this...well except for a small skinny black cable next to that big Molex (looks like a PC Molex connector anyways) connector, it seems to be going up into the dashboard?
Thank you.
Old Jun 23, 2013
Yes that is an aftermarket unit, looks like a keyless or an alarm. Not sure why you wanted to locate it, but you found it. It looks like the back of the box has the wire designations stamped into it if you want to go chasing individual wire connections.
Old Jun 23, 2013
god_43's Avatar
lol i probably should have mentioned that it has not worked for the last 7 years. so i am looking to replace it.
Thanks for the help.
jessicakaybby
Apr 20, 2015 12:11 PM
vino
Nov 3, 2001 11:08 PM
