Lower Timing Cover Shredded + Oil Leak Issue
Old Feb 8, 2026
oiji2000's Avatar
oiji2000 is an unknown quantity at this point
Hello everyone,
Long-time lurker, first time posting - thanks for your grace! I have a 2002 Honda Civic LX with a D17A1 engine and 250k on the thing. I did a head gasket job back in 2022 at 220k, and I'm afraid that this is coming back to haunt me and causing me grief with an oil leak, but figured I'd post to re-affirm my hypothesis. I'll sheepishly admit that I had a "minor" oil leak that I've been living with for the past few years, but it never accumulated on the ground. I just did an oil change and looked over to the timing belt side from the bottom and found that the lower timing cover was shredded to bits and I can actually see the timing belt. Any thoughts or suggestions would be appreciated from you gurus out there! Thank you in advanced! Pictures enclosed.
#1. Picture of head with some oil around the engine head area.
#2. Same area but closer
#3. Lower timing belt cover shredded around the Crank area, and harmonic balancer off.
#4. Oil Pan area, left of lower timing belt cover.
#5. Lower timing cover with plastic bolt holders completely sheared or melted off.
#6. Lower timing belt cover is off
#7. Timing belt Camshaft pully view (straight view)
Thank you for reviewing and providing your suggestions! I can always take some more pics as well, but I figured I'd get the conversation started.
ncc74656
Aug 5, 2023 06:10 PM
Reinhardrules
Engine Management
Jun 14, 2021 12:13 PM
sponiebr
Jan 5, 2018 05:29 PM
Daniel Fenn
Jul 9, 2017 01:23 PM
packrat79
Apr 14, 2014 08:10 PM
