2005 Civic Hybid throwing P2000 code
Old Dec 21, 2023
samerickson89's Avatar
samerickson89 is an unknown quantity at this point
I had a MIL pop up on my 05 Civic Hybrid yesterday, and when I read the code today it came up as P2000 "NOx adsorptive catalyst efficiency below threshold
Digging around online, I found two Honda service bulletins that seem like they could apply:Both seem to say that it's an errant code, and that it just needs the PGM-FI to be updated, but they give different locations to punch the VIN to indicate the update has been completed. They also give different Program ID and Program P/N. So my questions are:
  • What's the difference between these service bulletins?
  • Does the 2011 bulletin supersede the 2007 bulletin (meaning I can just do the update mentioned in the 2011 bulletin)?
  • What exactly is PGM-FI software?
  • Can I update it myself, or would it have to be at a shop or dealership?
P.S. I did find this older thread about the same issue, but wasn't sure how people on this forum feel about resurrecting decade old threads.
Thanks!
Old Dec 21, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2005 Civic Hybid throwing P2000 code
  • The difference is one is specific to a set of VINs, the other is for all. Other than that, who knows.
  • If the 2011 bulletin includes your VIN, probably.
  • PGM-FI stands for programmed fuel injection. Referring to the ECU/PCM software.
  • Dealership is going to be the only ones with access. Unless you have a generic auto shop with all the Honda specific tools.
Old Feb 2, 2024
Thanks! The VIN wasn't stamped, but the dealership claims the update has already been done. Still trying to figure out where it was done so I can confirm.
If it really is a bad O2 sensor, how do I tell which one? My understanding (someone please correct me if I'm wrong) is that if the code is for catalyst efficiency then it would be a post-cat sensor. But which one would be bank 1 on this car?
bulls2030
Sep 14, 2017 07:56 AM
dizzle428
May 7, 2012 03:54 PM
LazyDog01
Vancouver
Jul 15, 2004 11:20 PM
Vinh
Feb 20, 2003 11:13 PM
