My Engine SINGS at 2500 rpm...
Old Sep 25, 2022
sponiebr's Avatar
sponiebr is an unknown quantity at this point
Unhappy My Engine SINGS at 2500 rpm...
Ok... Need some mechanical help. My engine starts to "sing" at 2500rpm. The singing goes away just above that mark and returns at a slightly higher pitch at the 2900 mark. Below are 2 videos detailing the singing sound (you might need some headphones to hear it) Some background on this: I JUST (less than 600 miles on the clock) put a new head on this engine after a broken timing belt. I replaced the timing belt tensioner (I used a Gates Powergrip kit that came with a GMB tensioner... NOT my favorite brand of tensioner) I did NOT replace the ASIN water pump as it wasn't even a year old when the timing belt broke. The head gasket was a Fel Pro.
I have isolated the issue to the engine area (e.g. it's not the transmission)
If you could shed some light on what you think it is I'd be very grateful for the help.
308747160_652919662815951_5699048414685316281_n.mo v
308751216_1763729390692182_2157427767047686779_n.m ov
Old Sep 25, 2022
Colin42's Avatar
Re: My Engine SINGS at 2500 rpm...
Probably the cheap tensioner
Old Sep 25, 2022
sponiebr's Avatar
Yeah, I was thinking the same thing. I'll replace it with an NSK.
tallal565
Jul 23, 2014 08:43 AM
trez777
May 8, 2013 03:33 PM
BR549
Apr 12, 2012 01:12 PM
imported_REDLINE
Sep 11, 2010 04:40 PM
grey2k11
Aug 21, 2008 02:28 AM
