Camshaft position sensor
Old Aug 30, 2022
Jlittle21's Avatar
Jlittle21
Jlittle21 is an unknown quantity at this point
Would my 2003 Honda Civic LX have a vvt solenoid I had timing belt and water pump replaced from a mechanic and now it keeps throwing cam sensor code and it won't let me get over 3,300 RPMs
Last edited by sdaidoji; Aug 31, 2022 at 08:07 AM. Reason: changed title to a more descriptive one, please help is not helpful
Old Aug 31, 2022
BrotatoChip's Avatar
Super Moderator
re: Camshaft position sensor
You should probably check engine timing. Would also be a good idea to check crank and cam sensors, make sure they were plugged back in.
Old Aug 31, 2022
Colin42's Avatar
And make sure he didn't put aftermarket sensors in
Old Aug 31, 2022
Super Moderator
Re: Camshaft position sensor
I guess best thing to do is just take it back to them. You paid them to do a timing belt and now have issues that could absolutely be caused by their work.
Old Aug 31, 2022
ah, typically after timing/water pump, high chances the sensors (camshaft/crankshaft) fail. Mine did.
could be grease/other fluids getting to them, could be because they were in place for decades and suddenly unplugged, etc
no VVT in D17A1, and honda calls them VTEC. VVT only changes timing, not camshaft lobes
Old Sep 2, 2022
Jlittle21's Avatar
Jlittle21
They're all plugged in and new they're refusing to fix the timing
Old Sep 2, 2022
Colin42's Avatar
New aftermarket? Junk, need oem.
Old Sep 2, 2022
Jlittle21's Avatar
Jlittle21
What's throwing me off with it is it gave me a code for the variable timing solenoid oil pressure switch but I don't have a VTEC unit anywhere
Old Sep 2, 2022
so do you have VTEC issues or camshaft issues codes?
VTEC - check if there is enough oil in the engine
Old Sep 2, 2022
Jlittle21's Avatar
Jlittle21
Fresh oil I don't even have a VTech solenoid on this one it's just the 1.6 LX but apparently I have a VVT oil pressure switch on it is with the code was coming up as and I still had the cam sensor code too but that's the only two
Old Sep 3, 2022
again, there is no VVT in the 7th gen civics. That's a different system, VVT changes the angle of the camshaft. The 7th gen cars have a VTEC-E, that changes from 3 to 4 valve operation - different animals (exception to Si model K-series engines).
What is the code you are getting?
Camshaft position sensor - I am not saying that they are unplugged. They tend to fail after being unplugged after decades in place.Or contaminated by grease or something during the job. Get a new sensor. Aftermarket does not agree with hondas, get a denso or NTK sensor. Or you can get one in a junkyard.
Old Sep 3, 2022
Jlittle21's Avatar
Jlittle21
I will definitely give it a try thanks
DahrkDaiz
37
Mar 3, 2021 10:38 AM
mik3boost
Sep 6, 2010 07:28 AM
gangulyarchan
Mar 12, 2010 10:48 PM
gangulyarchan
Mar 12, 2010 10:32 PM
SwedeCivic81
Mar 1, 2010 11:30 PM
