Civic is losing power and acceleration [solved]
Old Jun 14, 2022
Dice_of_Mars's Avatar
Dice_of_Mars is an unknown quantity at this point
Just did a tranny swap and timing belt replacement, car was running fine then all of a sudden the car is acting like it's not wanting to go over 3k rpm unless forced but feels bigger down when pushed harder. I have a recording on my drive of the diagnostics but it's Greek to me and I was wondering if anyone could glean any info from it. I can check stuff las posted. This is my only vehicle for work and I'm depending on it hard.
https://drive.google.com/file/d/17QbNRoYleNmHzyGjfrJAiOpTLhfw1td1/view?usp=drivesdk
Old Jun 14, 2022
re: Civic is losing power and acceleration [solved]
The picture is during acceleration if that helps.
Old Jun 14, 2022
Colin42's Avatar
Check engine light? Triple checked timing? Might be off a tooth
Old Jun 14, 2022
Unfortunately no check engine light, I verified TDC on correct turn of the crank but "​​​​​​​​​IF" the tensioner wasn't fully engaged it would possibly make it slip a tooth or so, but I replaced the belt because it had advanced one tooth initially and that was enough for it the computer to shut the car down, so if the timing not being correct was the culprit wouldn't it in turn behave the same way as before the replacement (start, stutter, stall). If the timing was off wouldn't it possibly give an invalid read against the crank and cam sensor and throw a code?
Old Jun 14, 2022
how long since tranny/belt? auto?
Old Jun 14, 2022
Tranny is a few months, the belt was about 2 months ago. It's an automatic.
Old Jun 14, 2022
so, not something related to the job, can cross that off.
Old Jun 14, 2022
I'm thinking it definitely has to be mechanical but not sensor recognizable since no code is being thrown, it doesn't really act up until shifting into 3rd gear, I'm hoping this tranny isn't acting up but the transmission wouldn't explain the limited rpms at least not without a code to tell it to go into limp mode right?
Old Jun 14, 2022
Colin42's Avatar
Egr passages? They can get pretty filled with crap and not throw a code
Old Jun 14, 2022
Wow **** complete oversight, me being an idiot trusted the ****ing guy at the dealership, put an extra quart too much oil, gonna see if I drain some if the problem persists hope I didn't do any permanent damage... I hope this is the issue
Old Jun 14, 2022
wow, belly full is hard to run
Old Jun 15, 2022
Colin42's Avatar
Glad you found it, should be fine once the oil is at the proper level
Old Jun 15, 2022
Thank you, and thank you everyone else, it seems to be acting better, sorry for the wild goose chase lol
Old Jun 15, 2022
Colin42's Avatar
No worries, it happens. We've all had weird car issues that turned out to be something simple and obvious in hindsight.
melpod87
Mar 18, 2013 12:20 PM
sellis1552
16
Mar 27, 2012 07:47 AM
chaz
Jun 3, 2011 08:12 PM
pp0225
Apr 5, 2011 02:18 PM
civic942008
Sep 24, 2008 06:37 PM
