SE EX Airbox Rattles
Old Feb 21, 2022
EricInAZ's Avatar
EricInAZ is an unknown quantity at this point
Got a junk 05 Civic that runs like a top - smooth, except for an annoying rattle at certain RPMs. The 2 halves of the airbox resonator fit loosely together at the front.
All securing screws are in place and tight.
Are there clips that hold the 2 halves together?
If all else fails, I can just wrap ducttape around the seam between the 2 halves.
Old Feb 21, 2022
BrotatoChip's Avatar
Super Moderator
Re: SE EX Airbox Rattles
If you're talking about the box the air filter is in then there should be like 7 screws on top holding it to the piece below.
Old Feb 21, 2022
EricInAZ's Avatar
No - as I had written, it's the airbox RESONATOR - there's no screws that secure the top and bottom halves together.
Old Feb 21, 2022
Super Moderator
Oops. The resonator is not supposed to separate. Maybe you can glue it back together, duct tape, or replace with a used one from a junkyard.
Old Feb 21, 2022
EricInAZ's Avatar
I'm thinking ducttape, since it's not under any real pressure.
Anyone know how these things were originally stuck together?
Old Feb 21, 2022
Colin42's Avatar
Probably some sort of epoxy, I would do epoxy since the duct tape will probably only last about a week
ElijahJ
General
Dec 29, 2021 01:50 PM
Phillip Lloyd
Engine Swaps
Apr 29, 2020 02:05 AM
jr0x29
Aug 6, 2009 10:33 AM
thenewdiabolic
21
Mar 16, 2009 06:27 PM
Killer_2006
Jun 29, 2006 11:46 PM
