oxygen sensors [solved]
Old Jan 13, 2022
Millsy088's Avatar
Millsy088 is an unknown quantity at this point
hi there, so i dropped my exhaust to be able to remove the subframe and in the process i cut the wires to both o2 sensors as i didnt have the foresight to place something under the exhaust to support it so it was hanging by the o2 sensors so i thought it best to cut the wires so the sensors dont get damaged and i would resolder them later, the issue being that both sensors have a grey, black and then 2 white wires, how do i tell which white wire is which? bonus: i need to fill my transmission with MTF and the only funnel i have that fits has been used for engine oil and still has some oil plus dust in there, can i use this for the MTF or should i buy a new one just for it (they're like $1.50)
Old Jan 13, 2022
re: oxygen sensors [solved]
just wash the funnel
Old Jan 13, 2022
Millsy088's Avatar
Alright that's pretty easy, and my car should still run with no oxygen sensors while I figure things out right?
Old Jan 13, 2022
it will throw a code and go into limp mode
Old Jan 13, 2022
Colin42's Avatar
Buy new sensors, they're probably pretty old at this point
Old Jan 13, 2022
the clp for the sensor can be painful to find where to press, but after you find it is is way easier to separate and reconnect than cutting and splicing later on, BTW... Slow in is faster
Old Jan 14, 2022
Millsy088's Avatar
I think that's the best idea, I'm not great at soldering either hahaha
05simplecivic
Mar 1, 2020 08:42 AM
Cross-Hair
Jun 13, 2014 08:04 PM
2slowem2
Aug 2, 2007 04:46 AM
StreetLevelPerformance
Feb 9, 2006 01:04 AM
RobearRacing
Oct 14, 2003 06:38 PM
