Compression on a 2003 with 240k miles
Old Oct 23, 2021
gts's Avatar
gts
gts has a spectacular aura aboutgts has a spectacular aura about
I did a compression test (just dry no wet test) on a 2003 with 240k miles.
All four cylinders were at 200 psi
Did a similar test on a 2008 with 123K miles and it too was 200 psi in all four.
Not sure what I was expecting but I was surprised the '03 with 240K was the same as the '08 with 123K.
Thoughts? Impressions?
Old Oct 23, 2021
FRSam's Avatar
Click Here
Re: Compression on a 2003 with 240k miles
What trim 2003 and what trim 2008?
Old Oct 23, 2021
Colin42's Avatar
If the engine was well maintained then that's expected
Old Oct 24, 2021
gts's Avatar
gts
Both were EX’s
Old Oct 24, 2021
FRSam's Avatar
Click Here
Originally Posted by gts
Both were EX’s
I’d definitely assume some compression tester error (I don’t think either of them made 200psi from factory) but it’s a good benchmark to see the engines are in good shape (consistent numbers all around, but I’d guess it’s closer to 160-170 which is still very good).
Enough carbon buildup on the Pistons would actually boost compression a bit. Wouldn’t shock me if that’s what’s happened with the ‘03
Old Oct 24, 2021
gts's Avatar
gts
That’s Interesting. Never heard about carbon build up having that affect but it makes sense.
I have a couple of other compression gauges/ testers. I’ll try those and see what happens. I still have access to the 2008.
Old Oct 24, 2021
FRSam's Avatar
Click Here
Mind you, the increase would be unsubstantial, but it’s an idea. I would think it’s more likely to be an engine that was either replaced or disassembled (head gasket for example)
My ‘01 was relatively well maintained but made like 120psi per cylinder when I sold it (200k-ish miles) so maybe I’m just bitter mine was a POS
Old Oct 25, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
I have an '05 EX and my compression numbers were between 173 and 200 psi. My mileage is lower (150K when tested), but it shows that the compression of these engines can get that high.
https://www.civicforums.com/forums/3...ml#post4787768
James Tyler
May 22, 2021 11:25 AM
Civic_RedLine
Jun 14, 2005 01:10 AM
acurastype01
Aug 6, 2004 02:59 PM
