Identify this plug(05 ex civic sedan)
Old Oct 14, 2021
Frostysinco's Avatar
Frostysinco is an unknown quantity at this point
The connection was on the back of the intake.
Thank you in advance
Old Oct 14, 2021
BrotatoChip's Avatar
Super Moderator
Re: Identify this plug(05 ex civic sedan)
I believe that's for the VTEC solenoid, would be back side of head on the passenger side. You should have a fault code if left unplugged.
Old Oct 14, 2021
I don’t have a code and I looked that up and that’s not it it’s one attached to the harness in the back of the intake.
Old Oct 14, 2021
Super Moderator
Post more pictures of where it is then. Below is a pic of the spool valve assembly. Two connectors, black one is an oil pressure switch, the gray one is for the VTEC solenoid. Gray connector looks exactly like the picture you posted. If unplugged I guess you wouldn't get a fault until it tries to engage VTEC.
Old Oct 14, 2021
Old Oct 14, 2021
do you know if it has anything to do with why it cranks starts then dies?
Old Oct 15, 2021
Super Moderator
That's right around where I would expect to find the VTEC solenoid connector.
If unplugged the engine should still run. Possibly limp mode or just no VTEC and a MIL. Would not cause it to start then die.
Old Oct 15, 2021
having that disconnected should throw a P1259 and toss you in limp mode. I know from experience when I had my 2002 civic turbo tuned and the tuner used the tuning unit to control VTEC and had it engage at 3500. The car ran normally otherwise, but limited RPM to 4000rpm (topped out at 80mph on an EX MT)
Old Oct 16, 2021
okay I don’t have a vtec solenoid there and not sure if I even have a vtec engine, there is three screw holes there tho like there used to be something there.
Old Oct 16, 2021
if you have an EX, you should have VTEC... can you take a look at the engine stamp and tell us what engine you car has?
If you don't know where it is
Old Oct 16, 2021
it doesn’t even have the sticker
Old Oct 16, 2021
it's engraved into the block
Old Oct 16, 2021
FRSam's Avatar
Click Here
It’s probably covered in grime. It’s definitely there.
Old Oct 17, 2021
Hey fellas is there any reason why it won’t run it starts runs dies immediately
Old Oct 17, 2021
there's a crap ton of things that could cause that. Any codes/check engine light being thrown?
Old Oct 17, 2021
Colin42's Avatar
Codes? Timing correct? Replaced any sensors with aftermarket garbage?
Old Oct 17, 2021
I did change the transmission fluid and that’s when it started happening
Old Oct 17, 2021
the timing is off I think
Old Oct 17, 2021
FRSam's Avatar
Click Here
It’ll throw a code if timing is off. You haven’t answered that question yet.
Old Oct 17, 2021
I had my timing off by a 1 or 2 with no code. Just ran like ****. Never died, nor felt like it wanted to die, but took forever to crank and ran like a dog with a sprained ankle
Old Oct 17, 2021
Colin42's Avatar
​​​​​​Well you should probably check that
Old Oct 18, 2021
it just says d171
Old Oct 18, 2021
okay update so I did the timing and it’s sticking clicking when the key is on I and ii and the engine won’t start now just cranks and no codes
plus a engine light on
Old Oct 18, 2021
FRSam's Avatar
Click Here
no codes plus a engine light on
The check engine light means you have codes. You need a code reader.
D17A1 means it's not an EX, unless it was swapped.
Old Oct 18, 2021
got a code po118 , clicking on the cluster and bad battery squeaking belt. Lol bout to just kick the car
Old Oct 18, 2021
FRSam's Avatar
Click Here
P0118 is a bad coolant temp sensor. It could cause a hard start.
Clicking is probably a bad battery. That's a pretty simple fix.
Have you tried holding the gas pedal down when cranking?
Old Oct 18, 2021
nah it started one time and now it’s like the battery is not strong enough
does this car need that ?
Old Oct 18, 2021
What's the color(s) on the wire insulation?
Critical info.
it just says d171
D17A1 ? or just D17A ?
Critical info.
VIN breakdown would show trim level and therefore vtec equipped originally or not
[headscratch.jpg] Nope. Just happens. No reason at all.
Old Oct 19, 2021
Critical info.
Critical info.
my bad ezone didn’t mean to leave you hanging It’s just I been putting a lot of time in on the civic
its d17a1
and by insulation what’s that
Old Oct 19, 2021
Super Moderator
Either your car isn't an EX or the engine was replaced with a non-VTEC D17A1 at some point.
