Misfiring ahhhh [solved]
Old Aug 3, 2021
  #31
BrotatoChip's Avatar
Super Moderator
re: Misfiring ahhhh [solved]
Originally Posted by Torbinator
a friend showed me VTEC heads I should save for.
You do realize that's an extra 12 HP, right? Does the cost of a replacement head, wiring, and VTEC ECU justify 12 HP?
Old Aug 3, 2021
  #32
and the key programming
Old Aug 3, 2021
  #33
Wankenstein's Avatar
Just was gonna do it for preventative maint
Guessing about tolerances is not preventative maintenance. Why bother doing it at all if you're not going to do it correctly?
Let me guess, you used an Ebay gasket?
Old Aug 4, 2021
  #34
Torbinator's Avatar
02 Civic DX 5spd. Ran by 4 little hamsters
Torbinator is an unknown quantity at this point
I've made it quite obvious that I don't care... This is my beater toy and if it blows I have another vehicle I can drive. Gasket has been replaced with a felpro and is running great. I would be replacing the head since it is quite worn. Heck I'd replace the engine if I can find a decent one when I go to do it.
I didn't ask for negative opinions. Quit wasting your time on this thread complaining about someone else's decision and help someone else.
I originally opened this thread being curious about a misfire. Leaking coolant I could care less about. Just trying to make this engine last my $800 worth. Thanks guys.
Old Aug 4, 2021
  #35
If the leak is between two cylinders it will cause low compression in each cylinder and a misfire. Coolant leaking into cylinders can foul plugs and cause a misfire. A breach can get worse and then the engine is more likely to start overheating, but hey you "probably" fixed it, right?
Old Aug 4, 2021
  #36
by experience, while the engine is running, combustion gases will leak into the coolant and push coolant out of the reservoir when it gets full. When not running, coolant seeps into the cylinders and causes misfires when the engine was just started and cold, yes.
Old Aug 4, 2021
  #37
This too. Happened on a BMW E46 I bought for my daughter a few years ago.
Old Aug 10, 2021
  #38
Torbinator's Avatar
Gotta update I have not lost any coolant since the gasket change and I fixed the misfire after I found out crankshaft sensor went bad... Fixed crankshaft sensor and now it runs perfect and isnt losing any fluids. Now onto suspension. Thanks guys!
vicLX
Mar 11, 2003 10:39 PM
S2000man01
Feb 25, 2003 08:18 PM
ice2000
Jan 30, 2003 11:27 PM
neeedforspeeeeed
Oct 30, 2002 02:49 PM
