Rattle from engine bay on decel
Old Apr 20, 2021
pitnut's Avatar
pitnut is an unknown quantity at this point
have have a 2005 civic 1.7L and I've recently noticed a rattle coming from the engine bay on deceleration. I can hear in two scenarios, while coasting in gear foot off gas (the rattle will go away as soon as I touch the accelerator). The second scenario is in neutral and at a stand still, I will rev the engine and as the RPMs fall it will rattle (pushing the clutch in and out has no effect on the rattle)
At first I thought it possibly a bearing from the transmission but I'm starting to lean towards a cracked header as I've heard that is a common issue with similar symptoms, there seems to be no loose heat shields or exhaust piping but I will take a closer look soon. Has anyone had a similar problem to this?
Car has 340k Km and I recently pulled the transmission to do a clutch kit as well as rear main seal.
Any help is appreciated!
Old Apr 21, 2021
Re: Rattle from engine bay on decel
removing the header is quite easy, 15-30 minutes, as long as you can remove the frozen bolts...
Old Feb 4, 2025
grapecivic's Avatar
grapecivic is an unknown quantity at this point
this sounds too similar to the problem i’ve been having, did you ever figure out what it was?
rnouri
Sep 16, 2012 07:58 PM
Krumenager
Mar 3, 2009 12:21 PM
wintermute
Jan 6, 2009 01:14 AM
DesertStriker
Sep 6, 2006 12:41 AM
conspiracy90
May 22, 2002 02:18 PM
