5 spd m/t
Old Mar 24, 2021
James Tyler's Avatar
James Tyler is an unknown quantity at this point
5 spd m/t
Thoughts and opinions
Old Mar 24, 2021
FRSam's Avatar
Click Here
Re: 5 spd m/t
Gonna need a little more than that lol
Unless there’re pictures that I can’t see
Old Mar 25, 2021
BrotatoChip's Avatar
Super Moderator
Re: 5 spd m/t
You have two options (that I can think of). Rear main seal on the engine is leaking oil or the input shaft seal on the transmission.
Old Mar 25, 2021
Re: 5 spd m/t
Well since my “simple” timing belt and tensioner installation during which I discovered both the top mounts, engine and tranny, had been “engineered” to appear normal to a cursory look, this has turned into a full blown engine swap because of an engine knock so....as a previous thread of mine stated, this is sooooo much fun. Lol
Old Mar 25, 2021
Super Moderator
Re: 5 spd m/t
Nothing like trying to fix a problem and finding two more, huh?
Old Mar 25, 2021
Re: 5 spd m/t
If it were only two, lol, I knew better than to let my buddy’s “good” mechanic work on my car but I figured, hey how bad can you mess up and oil change and brakes, it’s not rocket science and he’s a good guy and it’s been a long week for me at work.....never again.
I haven’t had to do this much on a car in awhile what’s the best way to go about determining which one is bad if not both, lol, cause if it’s the rear main seal that can wait?
Old Mar 25, 2021
Super Moderator
Re: 5 spd m/t
Were you constantly adding oil to the engine or transmission? Is the transmission really low on fluid? If the trans is still full and you haven't been adding any that would indicate it's the engine.
If it were me I would clean it up the best I could, replace the throwout bearing (and possibly clutch due to oil contamination), and replace the rear main seal. Of all the different Honda's I've worked on I've never seal the transmission input seal leak but who knows, that is a lot of oil/fluid/grease.
Old Mar 25, 2021
Re: 5 spd m/t
Alright, that actually makes perfect sense since I was having to add quite a bit of oil to the engine and could not figure out where the heck it was going. I had replaced everything but the kitchen sink when this horrendous knock started. I guess I will replace the rear main and then sell, as I have already purchased a newer replacement engine, in order to recoup a little bit of money. Hey many thanks and if I knew how to give rep I would, lol
Old Mar 25, 2021
Re: 5 spd m/t
Old Mar 25, 2021
Re: 5 spd m/t
on the bottom of the left box for the user, the 2nd icon from the left
Old Mar 26, 2021
Super Moderator
Re: 5 spd m/t
That is exactly the kind of noise you don't want to hear from an engine
user 70820122
South Cali
May 24, 2010 03:23 AM
02boostlessCIV
Jul 23, 2005 12:35 AM
cosmicjim
Jan 21, 2004 04:11 PM
