Oil leaking?
Old Jan 26, 2021
hond04's Avatar
hond04 is an unknown quantity at this point
Oil leaking?
Hey guys I have a 04 honda civic, that just had the crank shaft seal replace because it was leaking. Well now there is another place that's seems to be leaking. Does anyone know what it could be
Old Jan 26, 2021
Re: Oil leaking?
the highest point with oil is the culprit.
See other side of the engine and the side of the head.
typical ones are:
- VTEC solenoid (If you have)
- Camshaft end plug
- Valve cover (yours maybe good?)
Old Jan 26, 2021
hond04's Avatar
Re: Oil leaking?
I had already replace the cam shaft plug, I'll see if mine has a vtec solenoid
Old Jan 26, 2021
Re: Oil leaking?
you should have - I see in your pictures your block is D17A2. Unless someone swapped a non-VTEC head, that is
Old Jan 26, 2021
Re: Oil leaking?
if not the usual suspects...
Crankshaft seal or trans are leaking again... need check which is losing oil
Old Jan 26, 2021
hond04's Avatar
Re: Oil leaking?
here are some pics i took off were the vtec solenoid is located.
Old Jan 26, 2021
hond04's Avatar
Re: Oil leaking?
here are more pics
Old Jan 26, 2021
Re: Oil leaking?
looks like time to remove the VTEC solenoid, gaskets and don't forget to clean the filter while at it
mrat
Jan 11, 2021 06:30 AM
James Tyler
Dec 27, 2020 07:34 PM
kotsumo
Apr 9, 2020 01:57 PM
04civicexx
Dec 21, 2018 07:32 AM
civic2000abc
Jul 31, 2010 10:13 PM
