How-To: Fitting atop engine blew out and now leaks gas... HELP
Old Nov 6, 2020
kfo's Avatar
kfo
kfo is an unknown quantity at this point
Exclamation How-To: Fitting atop engine blew out and now leaks gas... HELP
I put the correct amount of seafoam into my gas tank early yesterday morning and when I got home last night about midnight, my car started chugging and reeking of gasoline. I popped the hood and saw a jet stream of gasoline spewing from this fitting.. what do I do?
birds eye view of engine
east of air filter
atop/east of air filter
fitting that is spewing gasoline
Thanks for any suggestions in advance.
Old Nov 6, 2020
BrotatoChip's Avatar
Super Moderator
Re: How-To: Fitting atop engine blew out and now leaks gas... HELP
Did you have the intake manifold off recently? You're missing a nut (red arrow) and your fuel rail is not aligned/seated on at least that fuel injector (red circle).
Old Nov 6, 2020
Wow, nice catch. I was so focused in on the injector not being seated in the fuel rail properly that I didn't notice that.
Old Nov 6, 2020
Colin42's Avatar
Someone was in there recently and didn't reinstall everything correctly. Nut and the injector, neither would be caused by the seafoam
Old Nov 9, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
More missing bolts and radiator cap...
Old Nov 9, 2020
Super Moderator
The throttle/cruise control cables are even loose, sitting on top of the dipstick.
Old Nov 9, 2020
Colin42's Avatar
What monkey worked on this car?
Old Nov 10, 2020
I'd actually be willing to bet those snapped off (at least the plastic where those bolts screw into) while either tightening or loosening. That plastic got brittle over time, at least in the ones I've seen.
In the coolant system's defense, at least it's only the overflow, and not the actual radiator cap missing.
Serious question, do you know who worked on this car last? Well, did anything major on it that required removal of the fuel rail, IM, and valve cover?
Juanma1980cr
Mar 25, 2012 05:25 PM
mike98
Mar 20, 2011 11:40 PM
97 Civic coupe
Jul 19, 2010 07:03 AM
nyyanks81
Dec 21, 2005 04:32 AM
slick
Feb 9, 2003 07:54 PM
