‘01 Civic LX hesitates at 4K rpm’s
Old Oct 6, 2020
EM2-EMMA's Avatar
I’m a guy. My car’s name is Emma.
EM2-EMMA is an unknown quantity at this point
When I’m in neutral or coasting, it will rev to 6000 fine. Only when I’m in gear will it hesitate around 4-4500 rpm’s. Engine shudders and hesitates... don’t think it’s limp mode. All gears same issue. NO CHECK ENGINE LIGHT
Thanks for any help
Top Answer
Oct 7, 2020
BrotatoChip's Avatar
BrotatoChip
Super Moderator
Re: ‘01 Civic LX hesitates at 4K rpm’s
I would guess fuel. Check fuel pressure when driving if possible. Probably needs a new pick up sock in the tank.
Old Oct 6, 2020
FRSam's Avatar
Click Here
Sounds like either a fuel or spark issue to me
Old Oct 6, 2020
EM2-EMMA's Avatar
I guess. I’m refreshing another D17A1 (not V TEC) to swap out, my current engine has 300,000 miles 😂
might need a tune up
But again, my engine WILL rev to 6,000 rpm’s, but only while in neutral... would that be ECU that’s fried or engine related you think?
Old Oct 6, 2020
FRSam's Avatar
Click Here
Check your spark plugs and coils. If those check out, it's probably fuel pump or something related.
Old Oct 7, 2020
Super Moderator
Old Feb 10, 2021
EM2-EMMA's Avatar
FUEL PUMP GUYS
Thanks so much! I didn’t think it was fuel related at all but a new pump and filter and I’m sending every gear!!
Old Feb 11, 2021
Super Moderator
Thank you for updating
Berteasterly202
Oct 6, 2020 11:04 AM
Praygoza
Sep 25, 2019 11:42 AM
rlbtkd1
Aug 19, 2012 08:55 AM
ValleyCivic
Apr 21, 2012 07:00 PM
civic0427
Apr 17, 2012 05:35 PM
