Valve adjustment
Old May 16, 2020
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Valve adjustment
So on my 2002 civic,manual transmission, whenever i adjusted the valve they always shift afterwards. Here is how i get it done. After taking off the valve cover I find cylinder #1 by turning the crankshaft counter clockwise then check the clearance withe correct feeler gauge then if it needs adjustment i proceed, after i adjusted one i hold the screw driver tight to make sure it doesn't move when drawing on the nut.i tighten it enough so it doesn't move when i torque it down then move to cylinder#3 with same steps by turning the crank again to find TDC. After I'm done i torque them down 15 ft pound. When I'm done with all four,i turned the crank over a few times and and rechecked them with feeler gauge but there was always a few that move,how they move i dont know. I correct them turn the crank again and rechecked them, some still move, i correct them and rechecked again. Put everything back together and in a about a weak or two, check them again like i was told by mechanic to check them after i few weeks and some of them always shift. What causing them to move after so much corrections? I always torque them down each time i finished with one before i move to the next one.
Old May 16, 2020
Colin42's Avatar
Re: Valve adjustment
Torque them tighter, try 20-25 ft-lbs
Old May 16, 2020
wow.that might Ruing the threadings.colin. i think the book said 15 ft pound.
and i dont want to mess up them. I want to readjust them. I put them at 0.009 intake and exhaust 0.0011.i i preferred 0.008 intake
0.009 exhaust slight drag.
Old May 16, 2020
Colin42's Avatar
An extra 5 ft-lbs is not going to ruin the threads, your torque wrench is probably not even that accurate at the lower end of the scale
Old May 16, 2020
ok.i will see next time.
Old May 16, 2020
Wankenstein's Avatar
I tighten them by the feel..never had an issue of them loosening.
Old May 16, 2020
no no, is not they got loos. Its just the space between the valve stems and the rocker arms got tighter or a little loose.
Old May 16, 2020
BrotatoChip's Avatar
Super Moderator
Are you accurately getting each piston at TDC? Using a rod or screwdriver in the spark plug hole may not be accurate enough. Are you using a wrench to hold while tightening the nut with a socket or something?
Old May 17, 2020
That's odd. Maybe worn valve springs or rocker issue? https://mooregoodink.com/valve-sprin...lpful-details/
Old May 17, 2020
Ok..i was thinking if i adjusted the intake at 0.007 and Exhaust 0.008 it maybe to close. Because if they are two close they wont open wide enough and also close all all the way. Also maybe burn out the valve stem over time. It may vibrate if they are too tight to
the intake valves always giiiive me one pain in the neck to adjust.they always move when i draw on the lock nut,no matter how i hold the screw driver steady in place they move.the Exhaust side adjust very easy.
Old May 18, 2020
Set at highest end of spec ranges for both intake and exhaust. Better loose (within range) than tight as valves tighten with use/miles.
Intake: 0.18 - 0.22 mm (0.007 - 0.009 inch)
Exhaust: 0.23 - 0.27 mm (0.009 - 0.011 inch)
Old May 18, 2020
thats the specific clearance i have on those. So i should keep it at 0.009 intake and 0.0010 Exhaust?
Old May 18, 2020
typo: 0.0010. Probably, if you set exhaust at 0.010 but my assumption is most people set their's in correlation as follows:
I = .007 E = .009
I = .008 E = .010
I = .009 E = .011
Tracecross30
Apr 26, 2020 06:23 PM
scooty
26
Aug 16, 2014 02:15 PM
Fabian
1st - 5th Gen Do It Yourself Articles
Oct 13, 2012 05:52 PM
dem0nk1d
Oct 12, 2012 01:08 PM
ohiojosh78
Oct 9, 2004 09:14 PM
