P0420 what can it be?
Old Apr 20, 2020
AangAirbender's Avatar
AangAirbender is an unknown quantity at this point
The other day my check engine light came on with the p0420 code, of course I want to check every problem before I chanhe the catalytic converter. I checked the o2 sensors and while the upstream sensor (bank 1 sensor 1) shows an alternating curve while driving, the downstream (bank 1 sensor 2) does not follow it like one would think. When idling sensor 2 indicates .2 volts, but when driving it shows higher numbers than sensor 1. Sensor 2 is at about .7-8 while sensor 1 is about .5. Is it possible that my sensor 2 is faulty? Help please
Old Apr 20, 2020
Re: P0420 what can it be?
my bet is for actual cat. I never took voltage readings, so I couldn't tell you voltage range for proper ops, but could be that your cat is literally under efficiency threshold.
Pure speculation here, coupled with very quick googling for numbers.. Average cat lifespan is 100k miles. Could also mean internal damage to the honeycomb structure, allowing more un-catalyzed exhaust gases (CO and NOx) being read by the secondary sensor. No lie, couldn't find anything concrete about the substrate(s) used (other than precious metals) and if/how they can be spent.
I mean, if the 420 code isn't causing any performance issues, there are ways to make that light go away, and I have passed OBD port smog checks with that mod in place. Just look up what people with high flow cats and/or test pipes do. Cost me like $3 to do
Old Apr 20, 2020
Slumpertcivic's Avatar
If your losing a quart plus of oil between oil changes (or fillups when really bad) it most likely is a clogged up cat.
If your really lucky like me, your clogged up cat will shatter and you will have chunks of black plastic like rocks all though your exhaust piping.
Bang the resonator few times and listen for rattles.
Old Apr 21, 2020
I am thinking about installing spark plug non foulers. Is it what you were talking about? I am open to any other possibility. The car sadly not worth the price of a new oem cat.
Old Apr 21, 2020
yep, that's it. Get the long one, you won't have to drill anything out.
Old Apr 21, 2020
Yeah I ordered that, now waiting for the shipping. I do not have any othet problems, it is not eating oil, nor gas so I hope it will solve the problem.
Thanks for the answers I appreciate it.
tide55
Dec 19, 2013 11:37 PM
sekhonjatt
Jun 24, 2013 08:09 PM
p7C
Oct 17, 2012 10:18 PM
BrickM
Sep 27, 2012 02:25 PM
Protan988
Feb 5, 2009 07:17 PM
