Low oil pressure?
Old Feb 5, 2020
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Low oil pressure?
Hello everyone, I just got done installing an oil pressure gauge in my 05 Civic, and I am a little bit concerned by my oil pressure. On a cold start it will go up to 80-90 PSI at idle, which seems fine. Holding it at 3000 RPM after the oil is fully warmed up (180 degrees), the oil pressure runs at around 70 PSI. Again, seems fine to me. But I'm a bit concerned about the oil pressure at idle. Once the engine heats up, it's only making around 11 PSI at idle (~750 RPM). If I raise the RPM to around 1000 it will make around 25 PSI, which seems alright to me. I just don't understand why it's dropping down so low at idle. No glitter in the oil, no concerning noises, and the oil pressure warning light never comes on. Is this something I should be concerned about, or is this normal for these engines? Thank you very much in advance, I really appreciate your help.
Old Feb 6, 2020
BrotatoChip's Avatar
Super Moderator
Re: Low oil pressure?
Service manual states oil pressure at idle should be no less than 10 psi (oil temp at 176F) and at 3k rpm no less than 50 psi.
Old Feb 6, 2020
Cool, thank you! So no need to worry, or is that too close to the lower limit for safety?
Old Feb 6, 2020
Super Moderator
It's within spec, I wouldn't worry about it.
Old Feb 6, 2020
Cool, thank you so much! At what pressure should I become worried? I know the spec is at 176F, but when the oil gets hotter than that my pressure will drop further, likely into the single digits. But I presume this is okay since the pressure is within spec at the oil temp the specs are given for?
Old Feb 7, 2020
Already answered
Also, have been using pressure gauge for many years - thats normal.
you simply did not know until you installed gauge
Old Feb 7, 2020
1989 Mazda miata came with full oil pressure gauge, many customers complained that the pressure looked low and Mazda had to change that to a idiot light type, full on or off because of customers that did not understand engine oil pressure.
Old Feb 7, 2020
Originally Posted by sdaidoji
Already answered
Cool, thank you!
Old Feb 7, 2020
Good point. From my understanding, a lot of vehicles with factory oil pressure gauges don't show true pressure for the same reason. Instead, the ECU receives the data from the pressure sensor and if it deems it acceptable for the current conditions the gauge on the dash will read near the middle, and if it doesn't it reads all the way down into the red. And the variations between idle and high RPM often look much less dramatic than they really are. The gauge goes up some with RPM because that's what people expect it to do, but really it's often no more useful than an idiot light.
Actually the stock temp gauge on these cars operates in a similar way. It doesn't show true coolant temp, just cold, normal, and hot. Between about 160 degrees and 230 degrees it doesn't move.
Nelrodjr
Aug 1, 2018 11:13 PM
Squeeken
Jun 11, 2013 12:03 AM
Jeff
Aug 11, 2006 12:38 PM
Jeff
Engine Swaps
May 22, 2005 07:17 PM
mdn139
May 13, 2004 10:50 PM
