Honda Civic 2005 lx
Old Oct 25, 2019
Inayat Shaheen's Avatar
Inayat Shaheen is an unknown quantity at this point
Honda Civic 2005 lx
Hey guys! I have Honda Civic 2005 lx four cylinder... I had the engine light one on this car for few months. The CEL code is p0135 which is bank 1 sensor 1 o2 sensor!
so I’ve replaced it, with a brand new one from Honda! And now my car is acting up, it has no power, it wants to die, and it shakes and chock to dead!
but as soon as I put the old o2 sensor on it, it works fine! But again I’ll get that CEL..
im thinking my cat is clot up, I feel like the car is dying due to it can’t breath.
any help ? Please ... or anyone had a similar problem would help a lot!
thank you guys !
Old Oct 25, 2019
BrotatoChip's Avatar
Super Moderator
Re: Honda Civic 2005 lx
With the new O2 sensor did you see any fault codes? Do the part numbers on the new and old sensor match?
Old Oct 25, 2019
I haven’t seen any code due to car just want tor die. So with a new o2 sensor on I can’t drive the car Bc it wants to die. And yes the part number matches .
Old Oct 26, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
I have an 05 LX. Never replaced sensor 1. I did replace sensor 2 a few years ago with no troubles. In your case the only thing that makes sense is that the new sensor is no good. Assuming Honda gave you an actual Honda part (which I am sure they did). Still a new but not working new sensor should not result in the poor performance you describe. If the cat was severely clogged it would affect your power and performance regardless of which sensor you have in there, old or new I would think.
Old Oct 26, 2019
Should I try to reset the EUC? Would that help?
Old Oct 26, 2019
if it is my car I wouldn't. I do not know if resetting the computer will help. What you do know is that It runs OK with the old sensor in there. I would leave the old one in there, use the car. And in the meantime do more research. Sounds like a piece of the puzzle is missing.
Old Oct 26, 2019
GolNat's Avatar
Prelude Owner
Did they give you a sensor for an 01-03 Civic maybe? They are different. Ones wide band the other narrow if I remember correctly!?!
Double check from another source on the part number. If the cat was clogged it would run like crap no matter what sensor was in there.
Old Oct 28, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Your 2005 LX takes an air fuel ratio sensor in Bank 1 and not an O2 sensor. Should be around $250 at Honda. See part #7 in this diagram: https://parts.sonshonda.com/showAsse...rimLevel=24896
MichaelEB
18
Jul 26, 2014 10:33 PM
tide55
Dec 19, 2013 11:37 PM
BrickM
Sep 27, 2012 02:25 PM
ssamson1989
Apr 18, 2012 12:36 AM
Protan988
Feb 5, 2009 07:17 PM
