Cylinder misfire
Old Oct 16, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Cylinder misfire
So last week Saturday i noticed my check engine light giving me 3 codes for misfire from cylinder 2 to 4. I went to the junkyard and got me 4 ignition coil ftom a car like my 02 civic amd put them in. Clear the codes after and everything went fine until this afternoon the check engine light showing the same thing agai. My plugs are about 4 months old since i installed them so what could causing me to have this issue?
Old Oct 16, 2019
GolNat's Avatar
Prelude Owner
Re: Cylinder misfire
What plugs did you use? Did you pull a plug and see what it looks like?
Old Oct 16, 2019
I replaced the plugs of the same kind that I took out .its dense that was in it when I replaced them and the parts store said it's those it required.
Denson Pkj200CR-L11
Old Oct 16, 2019
Colin42's Avatar
Gapped properly?
Injectors firing properly?
Old Oct 16, 2019
They were already pre-gapped. How do I checked the injectors?
Old Oct 16, 2019
Also I used injector cleaner in my tank at times.
Old Oct 16, 2019
GolNat's Avatar
Prelude Owner
The NGK I bought for my GTI were pre-gapped also but 1 out of the 4 was not correct. You should always double check before install.
Old Oct 16, 2019
Ok...I dont know anything about gapping spark plug..I dont know the carrect way and I dont have tools for plug gapping either..
Old Oct 17, 2019
Colin42's Avatar
YouTube, a gap tool is like $4
Old Oct 17, 2019
Ok...i ordered 4 coil pack.i will see what will happen after i installed them.i will update you on this topic afterward.
Old Oct 17, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
It might be to your benefit to look on you tube for some videos on testing coil packs. It would be nice to know if yours are causing the misfire or not.
Old Oct 18, 2019
Ok. I will do that.
Old Oct 18, 2019
Ok. I came up with this idea just now..i started the car and while it is running, i unplugged the wire from each coil pack and the engine did made changes for each of them. The idling changes each time i unplugged them..
I dont know what to think at this time.. I dont know the plugs are new , about 3 to 4 months old. I dont see any cuts on the plug wires.. I dont know if i should get plugs from the dealership and try or even though the coil packs didn't show any signs of them being faulty if i should still change them since i ordered a set of new once.?
Old Oct 18, 2019
BrotatoChip's Avatar
Super Moderator
What about clogged EGR runners causing misfires? Usually there is a fault for EGR at the same time but in the thread below there was not.
https://www.civicforums.com/forums/3...g-misfire.html
Old Oct 18, 2019
My EGR is valve is fine.. I replaced the gasket about a month now so i cleaned it before i put it back in place..
Old Oct 18, 2019
No lie, I gap plugs bu putting it in a spark plug socket attached to a socket extension and rolling the (ground) electrode on a block of wood while putting some pressure on it. Roll a little bit, check gap. Repeat if necessary
Old Oct 20, 2019
Super Moderator
Not talking about the EGR valve. There are runners in the intake manifold, this is how the gasses get back into the intake. They tend to clog from carbon build up causing misfire codes.
Old Oct 22, 2019
Ok ,gotcha. But I cleaned them when I work on the engine about 4 months ago.
Old Oct 22, 2019
I might have a bad fuel pump because I'm not getting proper reading from them..
Old Oct 22, 2019
Super Moderator
What fuel pressure are you reading? Should be 40-47 psi according to the service manual.
Old Oct 22, 2019
I took it to the dealership today and they said that they dont see anything wrong. No fault codes, fuel pump was ok,everything was reading fine and the diagnostic machine except for the spark plugs thats in there thats not the right once but its the same denso brand that honda use. They said it might be bad fuel in the tank so i put some Sea foam in the tank. I will change my gas station because they told me to stay away from the cheap gas stations.
Old Oct 22, 2019
Colin42's Avatar
Just because it's a Denso spark plug doesn't mean it's the right one. Denso probably makes a hundred different spark plugs. Put the Denso plugs with the correct part number in.
Old Oct 22, 2019
Denso IK22's were the spark plugs to get for the 7thgen back when I was dicking around with Azumi
Old Oct 23, 2019
Yeah. That's why i ordered from the dealership yesterday
I should pick them up today . Its $ 20 for one of each. I couldn't believe it when I heard the price .
Old Oct 23, 2019
Super Moderator
Dealer is usually more expensive. Looks like you can get the stock NGK ones on Amazon for $11 each or a parts store for $14 each. I have heard there are lots of knock-offs though so from the dealer is probably safest.
Old Oct 23, 2019
dude... dude...
Old Oct 23, 2019
ahhh hate to ask perhaps I missed it... did you figure out that the plugs indeed caused the misfire. Dealer states there was no misfire. I am confused. Oh well. Glad you got it worked out.
Old Oct 24, 2019
Hey, i just go ahead and bought them from the dealership..the only difference on the plugs are that the once that i bought ftom advance Auto are that they have one letter beside the the 3 or 2 once on the plug and they made in the US and the once from the dealership have m11 on them and they were made in Japan..the light came this morning again before i replace the plugs. I'm going to scan it to see if its the same misfire codes.my catalyst converter need to change so it triggers the check engine light sometimes.
Old Oct 31, 2019
So I'm still having the codes coming up in the system for cilynder misfire 2-4. I got the original plugs from the dealership and i changed the coil packs and I'm still have the issue. The dealer checked for possible cause and they said that the only thing they could say causing the problem is bad gas so i put a bottle of seafoam in the tank and change where i buy gas and i clear the codes and two days later it came back.i dont know what else to do.any suggestions ?
Old Oct 31, 2019
Marcelo Souza's Avatar
Marcelo Souza is an unknown quantity at this point
Tell me what rpm it misfires, how long ago you changed your transmission fluid (it’s relevant), what gas you use, and what your batteries CCA( cold cranking amp) and CA(cranking amps) and if auto or manual, I have a turbo one that used to misfire I have been tweeking it for 2 years here is a pic
