Power Steering Pump Squealing Noise
'01 ES Dimension
My power steering pump is making a squealing noise whenever I rev the car. I thought that the tension of the belt is kinda loose so it is making the noise but when I checked it, belt tension is okay. Fluid is in the proper level and I am not having problem steering the wheel. It's just that it only makes the noise when I rev the car.
What would be the cause of this and how to fix it?
Re: Power Steering Pump Squealing Noise
Did you check the condition of the belt or just the tension?what about the alternator belt? You could try tightening it a bit more
Other Hondas, Odyssey and Accord comes to mind, have an o ring at the power steering pump that when it goes bad creates a grinding type noise in the pump. It lets air into the pump. Replace it and problem solved. There are a few vids on YouTube about it. Not sure if your car has the same O ring. I am not sure if my civic has it, never heard a noise from my civic pump. My Odyssey had the problem was an easy fix. Good luck
The ps pump and alternator belt is in good condition. And I've tried to rev the car without the ps pump belt, and there's no noise so I am sure that it is coming from the pump.
Haven't tried turning the wheel while holding the rpm. I'll give a try. But when I hold the rpm 2k and above, the annoying sound is there.
FijiEM2
Jul 18, 2017 08:17 PM
rb26dett26
Jan 28, 2016 07:30 AM
bert296
Nov 5, 2014 06:10 AM
Rahway09
May 1, 2013 01:02 AM
cschneider27
Mar 2, 2010 12:22 PM
