Strange A/C Noise
Old Aug 27, 2019
montoya661's Avatar
montoya661 is an unknown quantity at this point
Exclamation Strange A/C Noise
Can anyone figure out what may be the cause of this noise? it only occurs with the a/c on during acceleration or when I give it some throttle in park. All of the belts on the car are brand new as I just did a headgasket job and this noise was an issue before I did the job so it is not a result in the head gasket work.
https://www.youtube.com/watch?v=W7O9...ature=youtu.be
Here is a video for reference.
Old Aug 27, 2019
Wankenstein's Avatar
Re: Strange A/C Noise
Sounds like you have in alien in your engine..lol.
Accessory belts too tight? Sounds like metal against rubber but that's just a guess. Start buy checking the a/c tensioner pulley. Might be timing belt rubbing the timing belt cover? Water pump failing/squeeling. Use an auto-stethoscope or a piece of PVC pipe to listen more closely for noise source.
See if you can rev it to emulate these sounds (lol):
Old Aug 27, 2019
montoya661's Avatar
Water pump is brand new, the car doesn't make the noise without the A/C on and the timing is fine so its not the timing belt. I have a feeling it is the A/C compressor as that is what the belt rides on and the noise is only present when the A/C compressor engages the clutch and I accelerate.
Old Aug 27, 2019
What deflection depth did you use to determine belt tension?
AC compressor bearings noise? Possibly the compressor shaft is warped? https://www.google.com/amp/s/autoacr...bearing/%3famp
Old Aug 27, 2019
montoya661's Avatar
Basically this diagram
R3KogHyZe
May 26, 2016 12:53 PM
WaryDriver
Aug 22, 2015 06:50 PM
mistororange
Apr 4, 2014 10:39 PM
jimmyjames1387
Feb 15, 2013 11:57 AM
calpolyarc
Sep 1, 2011 12:22 PM
