Alternator adjustment bolt just fell out.
Old Jul 2, 2019
Slumpertcivic's Avatar
So yesterday I finally was motivated enough to replace the alternator / ps belts on my 2003 Civic. My son, who has been driving the car for last two years, told me it was “making” noises when the AC turns on back during spring break and I couldn’t remember buying new belts when I swapped the engine out the year before.
Generally I like to remove things to get better access to what I need to work on, so the first thing I start to remove is the power steering pump. Of course as soon as I get the bottom nut off, it falls and makes that classic thud sound as it gets stuck somewhere in the undershield. My son goes under to find it and comes up with a long bolt with a wingnut welded to the end and says this was down there too.
I recognized it immediately as the alternator tension bolt, but I have no clue how it would have been able to unscrew itself and fall out. Ended up having to remove the lower bolt so I could rotate the alternator upwards enough to get things to align right so I could spin it back in.
Forget just how much (not fun) it is to put actual Honda belts on, I was just about remove the lower bracket bolt again when we finally got it over the pulley using wood walking stick and a large c-clamp to stretch it over.
To prevent the bolt from coming out again, the only thing I was able to think of was to use a medium length zip-tie around the threads.
I figure that should prevent the bolt from spinning out on its own in the future.
Old Jul 2, 2019
Colin42's Avatar
Re: Alternator adjustment bolt just fell out.
wow, go buy a lottery ticket, lucky it didn't fry the computer
Old Jul 2, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Someone work on the alternator recently and not replace the adjustment bolt?
Old Jul 4, 2019
I would think the odds of my son tinkering and/or paying for someone to work on the car are 0. Love him, but he wanted “guidance” to scrap off the inspection sticker..
Being that I installed the engine back in and adjusted the belts 17 months ago, I would definitely have to accept the “fact” that Gremlins got into the engine bay at some point.
Old Jul 4, 2019
GolNat's Avatar
Prelude Owner
Definitely lucky it didn’t fry anything!!!
Might be good to have him inspect it every so often.
Old Jul 4, 2019
Colin42's Avatar
j.squared
24
Feb 1, 2014 05:57 PM
brian02
Aug 18, 2010 11:08 PM
laack
Dec 21, 2009 07:20 PM
DeX
Aug 7, 2007 09:40 PM
