Car jerking when cruising at all speeds
Old May 7, 2019
DrGottagupta's Avatar
DrGottagupta is an unknown quantity at this point
Unhappy Car jerking when cruising at all speeds
I am at a total loss with my car. Lately it feels like I fix one thing and another issue pops up. At first the car was jerking when accelerating and decelerating, the problem is still persistent. Now the car idles at 1500 rpm's at a cold startup, at any given speed the car shakes but most noticeable in 1st-3rd gear.
What can the issue possibly be?
Car Info:
2003 Honda Civic LX (5-speed)
146k Miles
Things Replaced:
Struts & shocks all around
NGK Spark plugs (last year)
Front engine mount
Transmission mount
Passenger engine mount
Valve cover gasket (still has a very small leak)
Cam plug
I am hoping that the issue is the rear engine mount, haven't had time to replace it.
Also I know for sure that the input shaft bearing went out as you can hear the bearing spin in 1st and 2nd gear.
Old May 7, 2019
Wankenstein's Avatar
Re: Car jerking when cruising at all speeds
Have you tried a smoke test for vacuum leak(s) ?
Valves adjusted?
Old May 7, 2019
Colin42's Avatar
exhaust/intake restriction?
Old May 7, 2019
clogged catalytic converter?
Old May 8, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
EGR valve and/or ports clogged?
raaxaa
Transmission
29
Sep 18, 2022 01:48 PM
PatsterBlaster
Jun 1, 2018 04:30 PM
Edisonsepulveda
Jun 8, 2013 07:52 AM
BmoreAMan
Buy, Sell, & Trade - Archive
May 19, 2010 11:51 AM
ZSKCivic01
Jan 30, 2006 03:58 PM
