dented rear main seal when installing...
Old Feb 13, 2019
elfred's Avatar
elfred is an unknown quantity at this point
I Install it right just some minor tap but I dont knoe what hsppened, when re-checking it after I saw this small light dent on the outer side edges of the seal, do I need to re replace this again?
Need opinion on this?
Thank you in advance!!!
Old Feb 13, 2019
Slumpertcivic's Avatar
Re: dented rear main seal when installing...
I would not expect any issues from that, even if you chunked off a bit it won’t leak unless you punch hole all the way through.
The inner lip is a different matter, one small nick on its edge will seep oil.
Old Feb 13, 2019
elfred's Avatar
Thank you!
elfred
Feb 14, 2019 10:24 AM
Kevin Morgeson
Feb 26, 2018 10:27 PM
sekhonjatt
Feb 27, 2013 10:25 PM
teampointless
Texas
Sep 13, 2004 09:49 AM
