Engine Skipping when Warm
Old Jan 10, 2019
tjohnny42's Avatar
2005 Honda Civic Hybrid
tjohnny42 is an unknown quantity at this point
Unhappy Engine Skipping when Warm
Hoping for some guidance: My 2005 Honda Civic Hybrid just recently began becoming sluggish and skipping when under heavy load (up steep hills, etc). The engine light will sometimes flash when this happens and will either stay on after or be off. When staying on, the codes include O2 sensor, all 4 cylinders misfires, catalyst. I suspected either clogged fuel injectors or water in the gas. I have added injector cleaner a few times and dry gas a few times. Doesn't seem to help. The issue happens less often at times (the engine light will be off for many miles) and other times it seems more often. downshifting is helpful for it with the higher RPMs, when climbing the long hills. Any suggestions? Why is it perfect when cold?
Old Jan 10, 2019
Colin42's Avatar
Re: Engine Skipping when Warm
Timing belt skipped a tooth?
Old Jan 11, 2019
Hybrid doesn't have a timing belt.
I'd kinda expect it may need a set of ignition coils (8) for the misfire
Not gonna speculate on the rest without a lot more info (exact codes), but misfires can ruin a cat
Old Jan 21, 2019
tjohnny42's Avatar
The situation seems to be improving. Still happening but much less frequently. Engine light hasn't flashed or come on in over a week. Still suspecting water or gunk in the fuel, OR O2 sensor issue. Does this model have 1 or 2 O2 sensors?
Old Jan 21, 2019
Good possibility, and just a little bit of water in the gas tank can be real frustrating to figure out
At least 2, and possibly a 3rd sensor depending on which version of the car you have.
O2 sensors don't typically cause misfire codes at random though
Old Jan 21, 2019
mac25's Avatar
Dr Krieger of Modification
If you want to isolate fuel as the cause, you should be able to lift the rear seats, unscrew the fuel pump lock ring, remove the fuel pump, place the fuel pump in a canister of fresh gas.
Also try checking the fuel pressure, and the ignition pulse (the signal to the injectors).
As well have you check spark while it is hot? You can unclip a fuel injector and pull an ignition coil to check the spark while the car is running.
Old Jan 22, 2019
digital-jesus's Avatar
digital-jesus is an unknown quantity at this point
Hi.. does your car have an egr? if it has and if the problem is until 2500 rpm try to unclog the egr passages in the intake nanifold. One passage for each cylinder..I had the same problem in a 2001 civic. Sorry my bad english
Old Mar 8, 2019
tjohnny42's Avatar
So.. the issue was nearly gone, until I just put fresh oil in the engine. It seems to be sputtering more again now.
Old Mar 8, 2019
mac25's Avatar
What viscosity?
New oil will be thinner across all temperatures, especially while hot. Perhaps you have low compression in a cylinder due to worn rings.
Check compression and report back.
Old Mar 8, 2019
tjohnny42's Avatar
No one has mentioned clogged cat. Conv. May this b the issue?
Old Mar 8, 2019
Colin42's Avatar
remove the front O2 sensor (check engine light will come on) and take it for a drive, see if there's any improvement in acceleration/driving
phoenixe1123
17
Aug 4, 2017 09:33 PM
2000.civic.ex
Nov 28, 2010 12:25 PM
jrzygrl73
Nov 19, 2010 12:03 PM
gangulyarchan
Mar 12, 2010 10:32 PM
ibsmitty
Jan 22, 2010 10:55 PM
